Error while building gcc for toolset for RTEMS
manish jain
manish8886 at gmail.com
Sat Feb 9 02:41:09 UTC 2013
No that didn't also work
*checking for style of include used by make... GNU
checking for sparc-rtems4.11-gcc... no
configure: error: no acceptable cc found in $PATH
make[2]: *** [sis] Error 1
make[2]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
I checked the path /opt/rtem-4.11 has sparc-rtems4.11-gcc.
Is there might be problem in configuring the rtems project. I first did
./bootstrap from rtems source directory and then configure the rtems and
tried to build it.
Thanks
Manish
On Fri, Feb 8, 2013 at 10:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
> 4.11 currently refers to the development head, or master. There is no 4.11
> branch at the moment. Try the master branch.
> The tools are specific to rtems version, so 4.11 tools will not build
> rtems 4.10.x
> -Gedare
> On Feb 8, 2013 4:57 AM, "manish jain" <manish8886 at gmail.com> wrote:
>> Hi All,
>> Thanks for all your suggestions. The problem was, library cache was not
>> updated. Now I have successfully built my tool chains for rtems-4.11.
>> But now I am facing problem in building the RTEMS itself.
>> I have built my tool set for rtems-4.11 but I am not able to find
>> RTEMS-4.11 source code in git repository and CVS. All I see is that most
>> current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
>> and tried to build it.
>> I am configuring the rtems with following command:
>> * ../rtems-4.10.2/configure --target=sparc-rtems4.11
>> --enable-rtemsbsp=sis --disable-posix --disable-networking --disable-cxx
>> --prefix=/opt/rtems-4.11
>> And the error I got when I do make all is following:
>> *configure: error: no acceptable cc found in $PATH
>> Actually after getting the error I saw "*
>> {build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that in
>> PATH: it is not including "/opt/rtems-4.11/bin" but in *
>> "{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is proper.
>> And my PATH variable is set to : *
>> /opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
>> I have looked the previous mails regarding this problem and most common
>> cause of this error was PATH variable but I think my PATH variable is
>> proper. I am not able to figure out why it is happening?
>> Thanks
>> Manish
>> On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
>>> > -----Original Message-----
>>> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>>> > bounces at rtems.org] On Behalf Of Gedare Bloom
>>> > Sent: Thursday, February 07, 2013 9:52 AM
>>> > To: manish jain
>>> > Cc: RTEMS
>>> > Subject: Re: Error while building gcc for toolset for RTEMS
>>> > Aside from the (relatively useful) advice that you may want to try
>>> > the prepackaged solutions, if you continue with building your own
>>> > tools you may want to check that mpc/gmp/mpfr are being found. If
>>> > you built/installed them separately from GCC then you need to add
>>> > the install point to your library path, e.g. export
>>> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
>>> > to where you installed those libraries. If you are using a single-
>>> > tree build where you link the source for those libraries, then gcc
>>> > should find them itself. The error you sent is indicative of a
>>> > missing library.
>>> If you continue on the path of building your own tools, the command
>>> "ldconfig -p" is your friend. This command will show you all the
>>> libraries known and cached. If you installed a library from source and
>>> don't see it listed, you may need to run "ldconfig" as root to update
>>> the cache. I've mostly seen this out-of-date ld.so cache problem on
>>> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/7f069236/attachment-0001.html>
