Problems in boot_card() with configuration
Matthew J Fletcher
amimjf at gmail.com
Fri Feb 15 17:03:22 UTC 2013
Gedare,
Its just a ARM7 variant, different to rtl22xx but not that exciting. Only
difference really is that its all in thumb mode.
On 15 Feb 2013 14:22, "Gedare Bloom" <gedare at rtems.org> wrote:
> I usually would start with the hello world and ticker samples for new
> BSP development. That limits the uncertainty I have.
> Are you planning to release your BSP / submit it to be included with RTEMS?
> On Fri, Feb 15, 2013 at 9:20 AM, Matthew J Fletcher <amimjf at gmail.com>
> wrote:
> > Joel,
> > I simply had not put
> > #define CONFIGURE_INIT
> > #include <rtems/confdefs.h>
> > Anywhere in the code, bit of a schoolboy error so the Configuration
> > structure was not setup. I was creating my own bsp and just forgot that I
> > needed bits from on of the samples as well.
> > On 15 Feb 2013 14:10, "Joel Sherrill" <Joel.Sherrill at oarcorp.com> wrote:
> >> Could you post or privately email the broken code? I am curious if we
> can
> >> do anything to help avoid this or at least make it easier to debug or
> know
> >> what tolook for in the future.
> >> Thanks
> >> Matthew J Fletcher <amimjf at gmail.com> wrote:
> >> Thanks all, but my problem was much simpler, not including confdefs.h I
> >> copied one of the included samples and am getting much further.
> >> On 14 Feb 2013 20:14, "Joel Sherrill" <joel.sherrill at oarcorp.com>
> wrote:
> >>> On 2/14/2013 2:00 PM, Matthew J Fletcher wrote:
> >>>> On 14/02/13 19:38, Gedare Bloom wrote:
> >>>>> On Thu, Feb 14, 2013 at 2:16 PM, Joel Sherrill
> >>>>> <joel.sherrill at oarcorp.com> wrote:
> >>>>>> On 2/14/2013 1:09 PM, Matthew J Fletcher wrote:
> >>>>>>> Hi,
> >>>>>>> I am using RTEMS 4.10.2, and a custom BSP based on the ARM rtl22xx.
> >>>>>>> I am running through the asm startup ok and calling into
> boot_card(),
> >>>>>>> stepping through its all working fine, work_area_start,
> >>>>>>> work_area_size,
> >>>>>>> heap_start and heap_size are setup as i expect from my linkscript.
> >>>>>>> But the test of "work_area_size <= Configuration.work_space_size"
> >>>>>>> fails
> >>>>>>> because Configuration.work_space_size looks like 0xfffffff, the
> only
> >>>>>>> place that assigns to Configuration.work_space_size is a few lines
> >>>>>>> further down.
> >>>>>>> Does this code presume that the BSP has set the Configuration
> >>>>>>> structure
> >>>>>>> to zero, or the whole memory ? even so the aforementioned test
> seems
> >>>>>>> odd
> >>>>>>> as its just testing memory has been initialised.
> >>>>> We do assume the .bss section is initialized to 0, although I'm not
> >>>>> sure if that is still a necessary assumption. But I don't think that
> >>>>> is the problem here, because if the value of
> >>>>> Configuration.work_space_size was 0 then this test would still fail.
> >>>>> The work_space_size calculation is done in the
> >>>>> cpukit/sapi/include/confdefs.h file, but that can be a bit messy to
> >>>>> try to figure out.
> >>>>>>> Or am i missing some RTEMS initialisation call that needs to be
> done
> >>>>>>> before boot_card() ?
> >>>>>> No but there may be some basic C language assumptions not
> >>>>>> being met. Configuration is in the .data section and that value
> >>>>>> does not look like it was initialized to.
> >>>>>> Is your download correct?
> >>>>> You can disassemble your binary image and inspect the value of the
> >>>>> Configuration.work_space_size field in the data section.
> >>>> Sorry i dont seem to have the objdump skills, i did a -D (disassemble
> >>>> all sections), although it produced massive output i dont see a
> >>>> structure called 'Configuration', i get a block like
> >>>> 814085f4 <Configuration>:
> >>>> 814085f4: 00000000 andeq r0, r0, r0
> >>>> 814085f8: 00010830 andeq r0, r1, r0, lsr r8
> >>> This isn't code but this is enough to see that what is in memory and
> used
> >>> by the code is NOT what was in the object. The workspace_address field
> >>> is 0. The second field is the size and is 0x00010830. You saw
> >>> 0xFFFFFFFFF.
> >>> Either the download didn't go where you thought, memory access isn't
> >>> setup write, etc.
> >>> Download and look at those two addresses BEFORE you run at all.
> >>> If you don't see those values, it is nothing to do with RTEMS. :)
> >>> .bss is uninitialized global and static date. It gets zeroed.
> >>> .data is your global and static data that is initialized.
> >>>> 814085fc: 00000000 andeq r0, r0, r0
> >>>> 81408600: 00002710 andeq r2, r0, r0, lsl r7
> >>>> 81408604: 00000032 andeq r0, r0, r2, lsr r0
> >>>> 81408608: 8118d3a0 tsthi r8, r0, lsr #7
> >>>> 8140860c: 00001000 andeq r1, r0, r0
> >>>> 81408610: 00001000 andeq r1, r0, r0
> >>>> 81408620: 00000002 andeq r0, r0, r2
> >>>> 81408624: 00000002 andeq r0, r0, r2
> >>>> 81408628: 8140868c smlalbbhi r8, r0, ip, r6
> >>>> 8140862c: 00000001 andeq r0, r0, r1
> >>>> 81408630: 8140866c cmphi r0, ip, ror #12
> >>>> is it possible to pretty print that in some way ?
> >>>>>>> - Matthew
> >>>>>>> _______________________________________________
> >>>>>>> rtems-users mailing list
> >>>>>>> rtems-users at rtems.org
> >>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
> >>>>>> Joel Sherrill, Ph.D. Director of Research & Development
> >>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
> >>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >>>>>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130215/20f49e03/attachment-0001.html>
