Problems in boot_card() with configuration
Gedare Bloom
gedare at rtems.org
Fri Feb 15 17:07:39 UTC 2013
Well, I encourage you to submit any modifications you found necessary
to get it working, if the board is likely to find other users.
On Fri, Feb 15, 2013 at 12:03 PM, Matthew J Fletcher <amimjf at gmail.com> wrote:
> Gedare,
> Its just a ARM7 variant, different to rtl22xx but not that exciting. Only
> difference really is that its all in thumb mode.
> On 15 Feb 2013 14:22, "Gedare Bloom" <gedare at rtems.org> wrote:
>> I usually would start with the hello world and ticker samples for new
>> BSP development. That limits the uncertainty I have.
>> Are you planning to release your BSP / submit it to be included with
>> RTEMS?
>> On Fri, Feb 15, 2013 at 9:20 AM, Matthew J Fletcher <amimjf at gmail.com>
>> wrote:
>> > Joel,
>> > I simply had not put
>> > #define CONFIGURE_INIT
>> > #include <rtems/confdefs.h>
>> > Anywhere in the code, bit of a schoolboy error so the Configuration
>> > structure was not setup. I was creating my own bsp and just forgot that
>> > I
>> > needed bits from on of the samples as well.
>> > On 15 Feb 2013 14:10, "Joel Sherrill" <Joel.Sherrill at oarcorp.com> wrote:
>> >> Could you post or privately email the broken code? I am curious if we
>> >> can
>> >> do anything to help avoid this or at least make it easier to debug or
>> >> know
>> >> what tolook for in the future.
>> >> Thanks
>> >> Thanks all, but my problem was much simpler, not including confdefs.h I
>> >> copied one of the included samples and am getting much further.
>> >> On 14 Feb 2013 20:14, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>> >> wrote:
>> >>> On 2/14/2013 2:00 PM, Matthew J Fletcher wrote:
>> >>>> On 14/02/13 19:38, Gedare Bloom wrote:
>> >>>>> On Thu, Feb 14, 2013 at 2:16 PM, Joel Sherrill
>> >>>>> <joel.sherrill at oarcorp.com> wrote:
>> >>>>>> On 2/14/2013 1:09 PM, Matthew J Fletcher wrote:
>> >>>>>>> Hi,
>> >>>>>>> I am using RTEMS 4.10.2, and a custom BSP based on the ARM
>> >>>>>>> rtl22xx.
>> >>>>>>> I am running through the asm startup ok and calling into
>> >>>>>>> boot_card(),
>> >>>>>>> stepping through its all working fine, work_area_start,
>> >>>>>>> work_area_size,
>> >>>>>>> heap_start and heap_size are setup as i expect from my linkscript.
>> >>>>>>> But the test of "work_area_size <= Configuration.work_space_size"
>> >>>>>>> fails
>> >>>>>>> because Configuration.work_space_size looks like 0xfffffff, the
>> >>>>>>> only
>> >>>>>>> place that assigns to Configuration.work_space_size is a few lines
>> >>>>>>> further down.
>> >>>>>>> Does this code presume that the BSP has set the Configuration
>> >>>>>>> structure
>> >>>>>>> to zero, or the whole memory ? even so the aforementioned test
>> >>>>>>> seems
>> >>>>>>> odd
>> >>>>>>> as its just testing memory has been initialised.
>> >>>>> We do assume the .bss section is initialized to 0, although I'm not
>> >>>>> sure if that is still a necessary assumption. But I don't think that
>> >>>>> is the problem here, because if the value of
>> >>>>> Configuration.work_space_size was 0 then this test would still fail.
>> >>>>> The work_space_size calculation is done in the
>> >>>>> cpukit/sapi/include/confdefs.h file, but that can be a bit messy to
>> >>>>> try to figure out.
>> >>>>>>> Or am i missing some RTEMS initialisation call that needs to be
>> >>>>>>> done
>> >>>>>>> before boot_card() ?
>> >>>>>> No but there may be some basic C language assumptions not
>> >>>>>> being met. Configuration is in the .data section and that value
>> >>>>>> does not look like it was initialized to.
>> >>>>>> Is your download correct?
>> >>>>> You can disassemble your binary image and inspect the value of the
>> >>>>> Configuration.work_space_size field in the data section.
>> >>>> Sorry i dont seem to have the objdump skills, i did a -D (disassemble
>> >>>> all sections), although it produced massive output i dont see a
>> >>>> structure called 'Configuration', i get a block like
>> >>>> 814085f4 <Configuration>:
>> >>>> 814085f4: 00000000 andeq r0, r0, r0
>> >>>> 814085f8: 00010830 andeq r0, r1, r0, lsr r8
>> >>> This isn't code but this is enough to see that what is in memory and
>> >>> used
>> >>> by the code is NOT what was in the object. The workspace_address field
>> >>> is 0. The second field is the size and is 0x00010830. You saw
>> >>> 0xFFFFFFFFF.
>> >>> Either the download didn't go where you thought, memory access isn't
>> >>> setup write, etc.
>> >>> Download and look at those two addresses BEFORE you run at all.
>> >>> If you don't see those values, it is nothing to do with RTEMS. :)
>> >>> .bss is uninitialized global and static date. It gets zeroed.
>> >>> .data is your global and static data that is initialized.
>> >>>> 814085fc: 00000000 andeq r0, r0, r0
>> >>>> 81408600: 00002710 andeq r2, r0, r0, lsl r7
>> >>>> 81408604: 00000032 andeq r0, r0, r2, lsr r0
>> >>>> 81408608: 8118d3a0 tsthi r8, r0, lsr #7
>> >>>> 8140860c: 00001000 andeq r1, r0, r0
>> >>>> 81408610: 00001000 andeq r1, r0, r0
>> >>>> 81408620: 00000002 andeq r0, r0, r2
>> >>>> 81408624: 00000002 andeq r0, r0, r2
>> >>>> 81408628: 8140868c smlalbbhi r8, r0, ip, r6
>> >>>> 8140862c: 00000001 andeq r0, r0, r1
>> >>>> 81408630: 8140866c cmphi r0, ip, ror #12
>> >>>> is it possible to pretty print that in some way ?
>> >>>>>>> - Matthew
>> >>>>>>> _______________________________________________
>> >>>>>>> rtems-users mailing list
>> >>>>>>> rtems-users at rtems.org
>> >>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> >>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>> >>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>> >>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> >>>>>> Support Available (256) 722-9985
