BSP instructions
Mathew Benson
mathew.benson at gmail.com
Sun Feb 17 20:50:28 UTC 2013
I definitely will, though I want to have a board to run it on first.
I'm not committing myself for anything yet, but I've been wondering if
there would be interest in an ARINC 653 APEX library for RTEMS.
On Sun, Feb 17, 2013 at 2:43 PM, rwas <rbtwas at gmail.com> wrote:
> Mathew Benson wrote:
>> I finally found the time to start playing with RTEMS. I'm a flight
>> software engineer, but have never written a BSP from scratch. I've
>> only tweaked existing ones. I have a Raspberry Pi B and would like
>> to use that as my test bed. Raspberry Pi is ARM based. It appears
>> the generic RTEMS ARM BSP is deprecated and has been removed. Two
>> questions. First, is there a tutorial, wiki, or some sort of
>> documentation on how to create a BSP? Second, which BSP should I
>> start with?
> Along with Gedare's response, I'd add that if you were determined to own the
> process, that you should learn to write standalone (--freestanding) code for
> this
> target.
> Robert W.
