ARM (Thumb Mode) _CPU_Context_switch_arm
    Matthew J Fletcher
    amimjf at gmail.com
    Mon Feb 25 17:25:32 UTC 2013
Sebastain,
I changed the code so now with the cpsr set as expected before main() the
context switch occurs fine and we end up in Init().
Thanks for all your help.
On 25 February 2013 17:10, Matthew J Fletcher <amimjf at gmail.com> wrote:
> Hi,
> The cpsr thats saved out to r2 is 0x800000df, but is restored back to
> 0x13. Thanks for pointing out that no cpsr change must happen, i will check
> how the rtl22xx_t bsp sets up the cpsr.
> On 25 February 2013 16:52, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
>>> Hi,
>>> r2 is 0x13 before the msr, so I guess new_level must have been 0.
>>> On 25 Feb 2013 15:02, "Sebastian Huber" <sebastian.huber at embedded-**
>>> brains.de <sebastian.huber at embedded-brains.de>
>>> <mailto:sebastian.huber@**embedded-brains.de<sebastian.huber at embedded-brains.de>>>
>>> wrote:
>>>     On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
>>>         Sebastian,
>>>         The _Thread_Heir->Registers are ok into the _Context_Switch()
>>> call, sp
>>>         and lr
>>>         both sensible.
>>>         At the 'mrs r2, cpsr' line sp is 0x40001b2c (rubbish) and pc
>>> sensible.
>>>         In _restore, after the 'ldmia r1, ...' instruction the sp and lr
>>> are loaded
>>>         with the correct values from _Thread_Heir->Registers.
>>>         Its the 'msr cpsr, r2' messes up the sp and lr
>>>     Ok, if you load undefined values into the CPSR, then a lot of things
>>> may
>>>     happen.  What is the value of r2 before the msr?  It should be 0x13.
>> Ok, then maybe the mode in the BSP execution context is wrong.  During
>> _Context_Switch() no mode change must happen.  What is the CPSR before the
>> msr?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> regards
> Matthew J Fletcher
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130225/e23abfc5/attachment-0001.html>
