Fwd: Re: rtems and Ubuntu 12.04
D Peter Siddons siddons at bnl.gov
Sun Jan 13 22:56:10 UTC 2013
-------- Original Message --------
Subject: 	Re: rtems and Ubuntu 12.04
Date: 	Sun, 13 Jan 2013 17:40:49 -0500
To: 	Ralf Corsepius <ralf.corsepius at rtems.org>
On 01/13/2013 01:42 PM, Ralf Corsepius wrote:
> On 01/13/2013 06:47 PM, D Peter Siddons wrote:
>> In building the RTEMS CVS head (4.10.99.0) on Ubuntu 12.04, 64-bit, I
>> discovered a problem. Make fails in the build with the "C compiler
>> cannot generate executables" error. I turns out that this is caused by
>> the libcloog.so library being renamed in this distribution to
>> libcloog-debian.so.0.0.0 and some similar links. I added a link from
>> this to libcloog.so.0 and everything built successfully. Is this a known
>> problem?
> No, I have no idea what you are talking about.
> Are you using my Ubuntu squeeze-packages?
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
Hi Ralf,
    Sorry, I forgot that bit of the story. I tried to use the Ubuntu
packages found in
http://www.rtems.org/ftp/pub/rtems/linux/4.11/ubuntu/pool/rtems4.11/r/
But there are unmet dependencies; I forget exactly which, but they were
packages xxxx-common, which I couldn't find anywhere. I also tried to
use the Debian packages in the same area, with the same problems.
In the end I did what I have done successfully previously, and used
Fedora packages via alien.
Is there somewhere else I should be looking to find a complete set of
Ubuntu packages? BTW I am building for the m68k architecture.
Pete.
OK, I may have not installed all of the needed packages from the Ubuntu
repository first time around. I will remove everything and try again without
my kluge.
Sorry,
Pete.
D. Peter Siddons
Detector Development Group Leader
NSLS, Bldg. 725D
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
URL: <http://lists.rtems.org/pipermail/users/attachments/20130113/7ba71ea6/attachment.html>
