Fwd: Re: rtems and Ubuntu 12.04
D Peter Siddons
siddons at bnl.gov
Sun Jan 13 23:15:37 UTC 2013
On 01/13/2013 05:56 PM, D Peter Siddons wrote:
> -------- Original Message --------
> Subject: Re: rtems and Ubuntu 12.04
> Date: Sun, 13 Jan 2013 17:40:49 -0500
> From: D Peter Siddons <siddons at bnl.gov>
> To: Ralf Corsepius <ralf.corsepius at rtems.org>
> On 01/13/2013 01:42 PM, Ralf Corsepius wrote:
> > On 01/13/2013 06:47 PM, D Peter Siddons wrote:
> >> In building the RTEMS CVS head (4.10.99.0) on Ubuntu 12.04, 64-bit, I
> >> discovered a problem. Make fails in the build with the "C compiler
> >> cannot generate executables" error. I turns out that this is caused by
> >> the libcloog.so library being renamed in this distribution to
> >> libcloog-debian.so.0.0.0 and some similar links. I added a link from
> >> this to libcloog.so.0 and everything built successfully. Is this a known
> >> problem?
> > No, I have no idea what you are talking about.
> > Are you using my Ubuntu squeeze-packages?
> > Ralf
> > rtems-users mailing list
> >rtems-users at rtems.org
> >http://www.rtems.org/mailman/listinfo/rtems-users
> Hi Ralf,
> Sorry, I forgot that bit of the story. I tried to use the Ubuntu
> packages found in
> http://www.rtems.org/ftp/pub/rtems/linux/4.11/ubuntu/pool/rtems4.11/r/
> But there are unmet dependencies; I forget exactly which, but they were
> packages xxxx-common, which I couldn't find anywhere. I also tried to
> use the Debian packages in the same area, with the same problems.
> In the end I did what I have done successfully previously, and used
> Fedora packages via alien.
> Is there somewhere else I should be looking to find a complete set of
> Ubuntu packages? BTW I am building for the m68k architecture.
> Pete.
> OK, I may have not installed all of the needed packages from the Ubuntu
> repository first time around. I will remove everything and try again without
> my kluge.
> Sorry,
> Pete.
I downloaded the amd64 flavor of packages from
http://www.rtems.org/ftp/pub/rtems/linux/4.11/ubuntu/pool/rtems4.11/r/rtems-4.11-m68k-rtems4.11-gcc/
and tried to install them. Here's the result:
# dpkg -i rtems-4.11-m68k-rtems4.11-newlib_4.7.2-0precise3_all.deb
Selecting previously unselected package rtems-4.11-m68k-rtems4.11-newlib.
(Reading database ... 465579 files and directories currently installed.)
Unpacking rtems-4.11-m68k-rtems4.11-newlib (from
rtems-4.11-m68k-rtems4.11-newlib_4.7.2-0precise3_all.deb) ...
dpkg: dependency problems prevent configuration of
rtems-4.11-m68k-rtems4.11-newlib:
rtems-4.11-m68k-rtems4.11-newlib depends on rtems-4.11-newlib-common;
however:
Package rtems-4.11-newlib-common is not installed.
dpkg: error processing rtems-4.11-m68k-rtems4.11-newlib (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
As far as I can see there is no package called rtems-4.11-newlib-common.
Pete.
D. Peter Siddons
Detector Development Group Leader
NSLS, Bldg. 725D
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
URL: <http://lists.rtems.org/pipermail/users/attachments/20130113/c726b838/attachment-0001.html>
