Inconsistency between bsp structure and erc32 user manual
Matias Pinedo
pinedomatias at gmail.com
Tue Jul 23 21:26:46 UTC 2013
Hello,
we are using rtems 4.10 and the ERC32 microprocessor.
When we tried to use the GPIO we found that there is an inconsistency
between bsp structure for erc32 memory mapped registers and the erc32 user
manual.
In the bsp structure for erc32 memory mapped register (erc32.h) says:
First_Failing_Data; /* offset 0xa8 */
First_Failing_Syndrome_and_Check_Bits;/* offset 0xac */
But, in the erc32 user manual it says that for the same offsets another
register names are used:
General-purpose Interface Configuration Register 0xA8
General-purpose Interface Data Register 0xAC
We successfully used the GPIO according to the erc32 user manual. Do you
think that the structure ERC32_Register_Map should be fixed?? or is there
something that I'm not seeing??
Thanks in advance and best regards,
Matias
URL: <http://lists.rtems.org/pipermail/users/attachments/20130723/4a408eb7/attachment.html>
