Why RTEMS timeslice is not as configured.
Fernando Nicodemos
fgnicodemos at ncb.ind.br
Thu Jul 11 21:55:28 UTC 2013
Just one correction. CPU is TSC695FL, not TSC695F.
*Fernando G. Nicodemos*
*Diretor de Pesquisa e Desenvolvimento
***®*NCB - Sistemas **Embarcados Ltda.*
*23° 09’ 24.87”S** 45° 47’ 26.49”W*
São José dos Campos - SP - Brasil
t.:+55 (12) *3905.2243* *
www.ncb.ind.br*
*AVISO:* Esta mensagem pode conter informações privilegiadas e seu conteúdo
é confidencial. É endereçada somente para destinatários conhecidos. Se você
não for um destinatário conhecido, não está autorizado a distribuir,
divulgar, imprimir, copiar e se utilizar desta mensagem e seu conteúdo.
2013/7/11 Fernando Nicodemos <fgnicodemos at ncb.ind.br>
> See answers bellow, in the text body.
> www.ncb.ind.br*
> 2013/7/9 Joel Sherrill <joel.sherrill at oarcorp.com>
>> On 7/8/2013 2:59 PM, Fernando Nicodemos wrote:
>> Dears,
>> I configured 4 equal Tasks in RTEMS and the table as follows:
>> rtems_task_create(
>> Task_name[ 0 ],
>> 2,
>> RTEMS_MINIMUM_STACK_SIZE * 2,
>> RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_ASR | RTEMS_INTERRUPT_LEVEL(0),
>> RTEMS_GLOBAL,
>> &Task_id[ 0 ]
>> They will operate in round-robin.
>> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>> #define CONFIGURE_TICKS_PER_TIME_SLICE 50
>> The result should show a timeslice of 500 milisseconds, but what i see
>> in osciloscope is more then 500ms, exactly 834ms. This code is running in a
>> ERC32 development kit from Atmel.
>> Where are the pins being written in the code to measure this?
> FER-> ERC32 GPIO pins are written. Each GPIO pin 4-7 is alocated to one
> task. See task code bellow (this code is the same for the 4 tasks, except
> for the respective GPIO):
> * RTEMS TASK 1
> rtems_task Task1(
> rtems_task_argument unused
> volatile uint32_t task1_wait_count = 2;
> * Generate a square output on GPIO4
> * Manual loop-striping was applied for optimization
> for(;;)
> SET(GPIO4);
> WAIT(task1_wait_count);
> CLR(GPIO4_7);
> Macros are:
> #define SET(gpio) ( *((volatile uint32_t *)ERC32_GPIDATR_ADDR) |= gpio )
> #define CLR(gpio) ( *((volatile uint32_t *)ERC32_GPIDATR_ADDR) &= ~gpio )
> #define WAIT(count) \
> volatile uint32_t i; \
> for (i = 1; i == count; i++) { }; \
> #else
>> Any ideas what is missing for this extra time?
>> What speed is the erc32?
>> I am curious if the assumed CPU speed is different from your actual
>> board.
> FER-> I did not change the default board values. I did not make any
> register configuration on core or system clocks. CPU is TSC695F wich leads
> a maximum 25MHz frequency. The board has two oscilators. One is 3.6864MHz
> and the other is 24MHz. So the CPU is running at 24MHz and sysclk is 12MHz
> (i measured in the sysclk pin and it is really 12MHz - remember that in
> ERC32 sysclk is automatically divided by 2).
>> Thanks,
>> Joel Sherrill, Ph.D. Director of Research & Development joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130711/429f56ec/attachment-0001.html>
