RTEMS on Virtex 4
Gempeler Stefan
Stefan.Gempeler at nanotronic.ch
Mon Jun 3 10:20:08 UTC 2013
Hi Chris,
thank you for your reply.
I use the rtems_task Init(rtems_task_argument argument). The main()
version consumes more memory and does not produce any output:
int main( void )
printk( "main() -- Hello World\t\t%s, %s\n", __DATE__,
__TIME__ );
sleep( 1 );
exit( 0 );
/* configuration information */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
text data bss dec hex filename
141380 1756 4332 147468 2400c rtems_libs.exe
This version produces output:
rtems_task Init( rtems_task_argument ignored )
printk( "\n\n*** HELLO WORLD TEST ***\t\t%s, %s\n", __DATE__, __TIME__
printk( "Hello World\t\t\t\t%s, %s\n", __DATE__, __TIME__ );
printk( "*** END OF HELLO WORLD TEST ***\t\t%s, %s\n", __DATE__,
__TIME__ );
exit( 0 );
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 1
126392 1724 4004 132120 20418 rtems_libs.exe
Stefan
URL: <http://lists.rtems.org/pipermail/users/attachments/20130603/25b20fb6/attachment-0001.html>
