RTEMS on Virtex 4
Sebastian Huber
Mon Jun 3 11:30:44 UTC 2013
Hello,
if I build the virtex4 BSP with the current Git master, then I get:
powerpc-rtems4.11-size hello.exe
text data bss dec hex filename
80867 1960 3845 86672 15290 hello.exe
This is the base line for RTEMS on PowerPC with printf() and Termios (other
BSPs have similar numbers). It is possible to save some bytes with tricks,
e.g. -ffunction-sections, -fdata-sections and -Wl,--gc-sections GCC options.
As a rough estimate I would reserve at least 80KiB for the base RTEMS system on
PowerPC.
On 06/03/2013 11:43 AM, Gempeler Stefan wrote:
> Hi Sebastian and Joel,,
> thank you very much for your fast replies. Sorry if I ruined your weekend, Joel ;-)
>>/ you execute the program out of the RAM?/
> Yes, that’s the plan. No additional memory (costs).
ok, and how do you boot the application? Can't you execute from flash?
>>/ printf() and the Termios interface (do you need it?) needs a lot of code space/
>>/ and the PowerPC code itself is not very dense. It is possible to strip down a/
>>/ RTEMS system, but in general RTEMS is not a ultra low code size system./
> I use the printk() to write data to the UART (also changed the printf() in
> c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c: bsp_XAssertHandler() to
> printk() -> no printf() in elf file).
printk() works polled.
> Hmm, when I set
> #define CONFIGURE_TERMIOS_DISABLED
> I get no output anymore. We use the UART as a simple debug console (output can
> be directly written to UART, input interrupt driven).
Most console driver use Termios, so if you disable Termios, then the console
driver doesn't work anymore.
>>/ The PowerPC BSPs should provide this interface:/
>>/ http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interrupt__extension.html/
>>/ In case this doesn't work with the virtex4 BSP, then we should fix this./
> I already tried it with rtems_interrupt_handler_install(), but it seems to be
> missing in the libs:
> undefined reference to `rtems_interrupt_handler_install'
> collect2: error: ld returned 1 exit status
I looked at the BSP code and unfortunately this BSP uses the old IRQ support.
Here you only have BSP_install_rtems_irq_handler().
> virtex4 BSP: at the moment I use the virtex and not the virtex4 BSP because I
> don’t know how to get the UART stdio working.
The virtex4 BSP seems to have no working console driver (only a dummy driver).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
