Error when building realview_pbx_a9 BSP
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Jun 11 12:50:01 UTC 2013
On 06/10/2013 03:03 PM, Sebastian Huber wrote:
> On 06/10/2013 02:45 PM, Ralf Corsepius wrote:
>> [2] arm-rtems4.11-gcc (eabi) was unbuildable on Fedora before 4.8.1.
> What was the build error?
There were several build errors acting.
* F19 ships texinfo >= 5.0.
This alone breaks many packages (e.g. RTEMS < 4.11, gcc-4.8.0,
gcc < 4.7.2).
* Building GCC-4.8.0 iced for arm-rtems4.11. I don't know the cause, but
would guess the target tuple change was incomplete in gcc-4.8.0.
Switching to gcc-4.8.1 fixed this
* GCC-4.8.0 in general failed to build on mingw.
Anyway, I consider the target tuple change to be a silliness and DO NOT
SUPPORT IT and do not want to look back into it.
You just should be aware, you caused me to waste time on this stuff and
that this thread is a direct consequence of your decison - Sebastian!
Ralf
