Error when building realview_pbx_a9 BSP
Sebastian Huber
Tue Jun 11 13:23:42 UTC 2013
On 06/11/2013 02:50 PM, Ralf Corsepius wrote:
> * Building GCC-4.8.0 iced for arm-rtems4.11. I don't know the cause, but would
> guess the target tuple change was incomplete in gcc-4.8.0.
> Switching to gcc-4.8.1 fixed this
It would be nice to get informed about such build failures.
> * GCC-4.8.0 in general failed to build on mingw.
> Anyway, I consider the target tuple change to be a silliness and DO NOT SUPPORT
> IT and do not want to look back into it.
> You just should be aware, you caused me to waste time on this stuff and that
> this thread is a direct consequence of your decison - Sebastian!
You should be aware, that you caused me also to waste a lot of time on this stuff.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
