SLAC RTEMS_gdb_stub_1_5 with RTEMS Git HEAD
Mon Jun 24 12:29:51 UTC 2013
On Mon, Jun 24, 2013 at 3:17 AM, Sebastian Huber
> Hello,
> On 06/24/2013 08:10 AM, Nick Withers wrote:
>> I'm trying to compile Till / SLAC's RTEMS_gdb_stub_1_5 against the RTEMS
>> Git HEAD and am having troubles...
>> Looks like the PPC Context_Control struct was changed significantly in
>> http://git.rtems.org/rtems/commit/cpukit/score/cpu/powerpc/rtems/score/cpu.h?id=1869bb7101de25205f325287419aaa25a13143c7
>> and now the PC and GPRs 2 - 13 inclusive are no longer exposed in the same
>> way (code mods to try to get at everything else below).
> this context may change again if we add the thread-local storage support for
> PowerPC.
>> I suppose I should just use 4.10.2 to get around this (and the other
>> issues that I probably haven't got far enough to run into yet), but a
>> couple o' questions first...
>>    - Anyone got it working on a PPC since the change?
>>    - Why isn't RTEMS_gdb_stub_1_5 part of RTEMS-proper?
> It would be useful to add this GDB stub to the RTEMS sources so we can keep
> it up to date if internal data structures change.
Rephrase: If you get it working with Git master branch we would be
glad to help merge and maintain it. ;)
> rtems-users mailing list
> rtems-users at rtems.org
