error in use of operator "new" with rtems
Luca Cinquepalmi cinquepalmi at planetek.it
Mon Mar 4 10:52:55 UTC 2013
The dimension of the object code is the double of the object code in case
I don't use the "new" operator. No error occurs in compilation, only a
dimension
enlargement which doesn't make my program work...
On 03/04/2013 11:48 AM, Sebastian Huber wrote:
> Hi Luca,
> On 03/04/2013 11:37 AM, Luca Cinquepalmi wrote:
>> Hi all,
>> I'm using C++ with rtems but when I use the operator new to
>> generate the object of my class my object code enlarge itself very much
>> even if the compilator (sparc-rtems4.11-gcc) doesn't declare any error.
>> What's the error depend on?
>> Is there any alternative solution? Thanks a lot
> what do you mean with "my object code enlarge itself very much"? Which
> error does occur?
Luca Cinquepalmi
Space System SBU
Planetek Italia s.r.l.
Via Massaua 12, I-70132 Bari
Tel.: +39 0809644200 Fax: +39 0809644299
cinquepalmi at planetek.it - http://www.planetek.it
