error in use of operator "new" with rtems
Mon Mar 4 12:11:09 UTC 2013
On 03/04/2013 11:52 AM, Luca Cinquepalmi wrote:
> The dimension of the object code is the double of the object code in case
> I don't use the "new" operator. No error occurs in compilation, only a dimension
> enlargement which doesn't make my program work...
Do you mean the code size of the final executable?  If you use the standard new
operator, then you depend on C++ exception handling and also some pretty
printing stuff (see GCC configure option --disable-libstdcxx-verbose).  You can
avoid some dependencies if you use the no-throw new (e.g. new(std::nothrow)).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
