RFC: Drop toolchain support for rtems4.8, rtems4.9 and CentOS5?
Matthew J Fletcher
amimjf at gmail.com
Thu Mar 14 07:07:24 UTC 2013
Ralf,
We use a mix of CentOS5/6. Would you consider branching the RPM build
scripts so you can use fun new stuff in for 6 hosts but keep the old
methods for 5 hosts ?
On 14 Mar 2013 06:40, "Ralf Corsepius" <ralf.corsepius at rtems.org> wrote:
> Hi,
> I'd like to drop/discontinue supporting the toolchain repositories for
> * CentOS5:
> CentOS5/RHEL5 is increasingly showing its age. Continuing to support it
> requires me to use anachronistic constructs in rpm.specs, which otherwise
> could be avoided and make life slightly easier for me.
> Q: Is anybody still using CentOS5 as RTEMS development hosts?
> * rtems4.8, rtems4.9 (All host OSes):
> I do not see much use in keeping these. RTEMS-4.8 and 4.9 and their
> toolchains haven't seen any activities for a long time and are de-facto
> dead.
> Keeping the packages, to me only means carrying around historic ballast of
> questionable value, I'd rather get rid off, ASAP.
> Opinions, comments?
> Ralf
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130314/1b43dbcd/attachment.html>
