problems with RFS filesystem and mkdir
Matthew J Fletcher amimjf at gmail.com
Mon Mar 18 17:20:25 UTC 2013
Hi,
I have an RFS filesystem using the nvram device, its formatted ok and
mount_and_make_target_path() also worked ok. But attempting to mkdir()
causes a really lowlevel issue.
The callstack;
rtems_rfs_block_map_find() at rtems-rfs-block.c:246 0x81198bd8
rtems_rfs_block_map_next_block() at rtems-rfs-block.c:353 0x81198d1e
rtems_rfs_dir_lookup_ino() at rtems-rfs-dir.c:204 0x8119951c
rtems_rfs_rtems_eval_for_make() at rtems-rfs-rtems.c:440 0x8118e142
IMFS_evaluate_for_make() at imfs_eval.c:435 0x81190718
mknod() at mknod.c:64 0x81183d5c
mkdir() at mkdir.c:29 0x81183cf0
build() at rtems_mkdir.c:101 0x811843a0
rtems_mkdir() at rtems_mkdir.c:136 0x811843a0
the rtems_rfs_block_pos_block_past_end macro is failing and causing the
return of ENXIO.
The two arguments to the macro are;
bpos->bno = 1
bpos->boff = 0
bpos->block = 0
map->size->count = 1
map->size->offset = 0
Which seems to me the cause of ENXIO being returned, but i dont know how my
BSP could affect this.
Do people use RFS in production systems ? i am using the 4.10.2 sources.
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130318/ff92a005/attachment.html>
