LEON3 Console/Serial Driver
Eric Norum wenorum at lbl.gov
Mon Mar 18 17:48:58 UTC 2013
Sounds like you want to put the line in termios "RAW" mode.
On Mar 18, 2013, at 9:52 AM, "Vincent Galbo" <vgalbo at aeronix.com> wrote:
> Hello Joel,
> I’m attempting to use the console as a message port for debugging (once we get SpW-USB dongles we will move to SpW). Our messages are hex based and the console doesn’t seem to like that. For instance, my application right now is essentially receiving from the console and sending the received message back out to the console. This works fine in console situations. For example, when I type “hello world”, I get the reply “hello world” back. However, if I send the console a hex based message, let’s say “0x90 eb 00 10 00 10”, I get some garbage back, such as “0x90 eb 50 54 50 5e”. I think it’s also waiting for an ASCII carriage return, because when I send it 0x0D (ASCII carriage return), I get some of the data I originally sent but with extra data mixed in. By the way, I’m using cutecom for these tests.
> So, my question is if I could somehow replace the console driver with a generic serial driver. One that doesn’t format, expect carriage returns, etc.
> Thank you,
> Vincent Galbo
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Monday, March 18, 2013 12:00 PM
> To: Vincent Galbo
> Cc: rtems-users at rtems.org
> Subject: Re: LEON3 Console/Serial Driver
> On 3/18/2013 10:38 AM, Vincent Galbo wrote:
> Hello,
> Does anyone know how to open the LEON3 console/serial port (/dev/console) with only a generic serial port driver rather than a console driver?
> What do you mean? It is a regular serial port. It is just associated
> with stdin, stdout and stderr.
> You can use termios to change any settings.  Treat it just like
> you would on a UNIX like OS
> Thank you,
> Vincent Galbo
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> rtems-users mailing list
Eric Norum
wenorum at lbl.gov
URL: <http://lists.rtems.org/pipermail/users/attachments/20130318/5db24953/attachment-0001.html>
