Library files for httpd and shttpd
Мозжухин Андрей Сергеевич amozzhuhin at ec-continuum.ru
Wed Mar 27 05:40:50 UTC 2013
for shttpd: --enable-shttpd
for mongoose: --enable-httpd
On 27.03.2013 05:42, Ahmed Patel wrote:
> Hi,
> I m trying to make the example from one of the network demos work. i saw that the mongoose needs a minimum stack size of 32k. hence thought of using the httpd or the shttpd. but i could not find any lib file which contains the functions of the httpd and the shttpd. is mongoose the only option now? or is there a still way out to use the others?
> i hv selected the enable-networking. the ftp and telnet are already running.
> Regards.
> On Tue 26 Mar, 2013 7:11 AM PDT Joel Sherrill wrote:
>> On 3/26/2013 3:07 AM, Ahmed Patel wrote:
>>> Hi,
>>> I understand that the functions available in the cpukit\httpd and the cpukit\shttpd will be available in the libhttpd.a and the libshttpd.a library files. But when i build RTEMS, these files are not generated. Is something special needs to be configured to generate these files or there is some different library file for the httpd and the shttpd webservers?
>>> I use RTEMS4.10.2 distribution.
>> Did you  build with --enable-networking?
>> How did you configure?
>> FWIW we have been through 3 web servers in the project history:
>> + GoAhead - replaced as project dried up. GoAhead was bought
>>    by Oracle after we dropped this and that was likely the final nail.
>> + Simple HTTPD - became Mongoose
>> + Mongoose HTTPD - current webserver solution
>> Mongoose is an active project and we periodically import a new
>> version.
>>> Thanks and Regards.
>> -- Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.org
Мозжухин Андрей Сергеевич,
начальник отдела
ЗАО "ИТЦ Континуум"
http://www.ec-continuum.ru
