problems with RFS filesystem and mkdir
Chris Johns
chrisj at rtems.org
Tue Mar 19 00:57:28 UTC 2013
Matthew J Fletcher wrote:
> Alas the mkdir() is the first filesystem operation i am doing. I am not
> sure if i can send attachments to the list so i've cut and pasted the
> relivant functions below. I guess the following would run on any BSP,
> its just a 256k block of sram. If there is a BSP with enough memory the
> base pointer for the filesystem could just be a big malloc().
I will need to get a working 4.10 build going and get your setting in.
This may take a few days.
