problems with RFS filesystem and mkdir
Matthew J Fletcher
amimjf at gmail.com
Tue Mar 19 09:35:20 UTC 2013
Hi,
I downloaded the GIT head this morning, looked at the rfs diff and seeing
there were some significant differences attempted to bootstrap to i could
see if the issue still existed.
Unfortunately bootstrap failed wanting autoconf 2.69, but the latest
official mingw autoconf is 2.68, from
http://sourceforge.net/projects/mingw/files/MSYS/msysdev/autoconf/
There was an experimental autoconf 2.69 floating around on the web,
installing that leads to issues with perl, etc i feel dependency issues
growing.
Do you think i could backport rfs from head back to 4.10.2, or would i end
up having to pull back all of libfs and beyond ?
On 19 March 2013 00:57, Chris Johns <chrisj at rtems.org> wrote:
> Matthew J Fletcher wrote:
>> Alas the mkdir() is the first filesystem operation i am doing. I am not
>> sure if i can send attachments to the list so i've cut and pasted the
>> relivant functions below. I guess the following would run on any BSP,
>> its just a 256k block of sram. If there is a BSP with enough memory the
>> base pointer for the filesystem could just be a big malloc().
> I will need to get a working 4.10 build going and get your setting in.
> This may take a few days.
> Chris
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130319/87eaa42c/attachment-0001.html>
