problems with RFS filesystem and mkdir
Wed Mar 20 14:22:17 UTC 2013
On 3/20/2013 8:30 AM, Matthew J Fletcher wrote:
> Hi,
> I wonder if this is target specific now, if i literately use the
> sources you posted i get an error '-1' returned from the rtems_mkdir().
> The only change i made was to malloc a smaller chuck, 32k. Of course
> my malloc() is operating of the same SRAM chip, but it was in a
> different address range.
> Not sure what to do now, i guess i have to work out whats up with RFS
> on ARM thumb. Does anyone know what platforms RFS was tested/developed
> on ?
These are tested by the fstests set of tests. I don't believe these were
in the 4.10
tree. Now these are tested on every target that has the testsuite run.
This would
primarily be i386, SPARC, MIPS, PowerPC, Coldfire and ARM. That's where most
of the daily developer activity is.
The code was initially developed and tested primarily on Coldfire,
SPARC, and i386.
Chris can say more about it specifically.
I would suggest that it would be good to see if this fails on 4.11 if
you haven't
already.
> On 19 March 2013 21:36, Cudmore, Alan P. (GSFC-5820)
> <alan.p.cudmore at nasa.gov <mailto:alan.p.cudmore at nasa.gov>> wrote:
>     No problem. I have a pretty easy to use 4.10 setup right now.
>     I did have to run the memset code for the address space. If you
>     pass a 0 in the cold_boot parameter, it fails.
>     Alan
>     On Mar 19, 2013, at 5:21 PM, Matthew J Fletcher <amimjf at gmail.com
>     <mailto:amimjf at gmail.com>> wrote:
>>     Alan,
>>     Thanks very much for running this test, its given me quite a bit
>>     of confidence.
>>     Did you have to memset the address space to 0xff before you could
>>     register/format the device ?, I found I had to do that to not get
>>     an error code.
>>     I suppose the memset would rapidly throw up problems if I had
>>     addresses wrong. I can't think what the issue might be. I will
>>     try a mallocd area like your example though to see if I get a
>>     good result.
>>     On 19 Mar 2013 21:05, "Cudmore, Alan P. (GSFC-5820)"
>>         I took your code below and created an example that would
>>         build and run on my 4.10.2 setup. I ran this on the sparc-sis
>>         simulator, and it seems to work fine.
>>         Are you sure you have valid memory for the nvramdisk device?
>>         We rely on RFS on 4.10.2 and are giving a pretty good stress
>>         test right now.
>>         Alan
>>         #include <errno.h>
>>         #include <stdio.h>
>>         #include <stdlib.h>
>>         #include <sys/stat.h>
>>         #include <fcntl.h>
>>         #include <rtems.h>
>>         #include <rtems/bdbuf.h>
>>         #include <rtems/blkdev.h>
>>         #include <rtems/diskdevs.h>
>>         #include <rtems/error.h>
>>         #include <rtems/flashdisk.h>
>>         #include <rtems/fsmount.h>
>>         #include <rtems/rtems-rfs.h>
>>         #include <rtems/rtems-rfs-format.h>
>>         #include <rtems/nvdisk-sram.h>
>>         uint32_t   rtems_nvdisk_configuration_size =1;
>>         constchar* sram_driver = "/dev/nvda"; //
>>         RTEMS_NVDISK_DEVICE_BASE_NAME, 1st device
>>         const char* sram_path = "/sram";
>>          * Let the IO system allocation the next available major number.
>>         #define RTEMS_DRIVER_AUTO_MAJOR (0)
>>          * The SRAM Device setup
>>         rtems_nvdisk_device_desc rtems_sram_device_descriptor[] =
>>                 flags: 0,
>>               base: 0,
>>                 size: 256* 1024, // 256K (Adjust when ROM.ld,
>>         _IMFS_DiskSize is changed)
>>               nv_ops: &rtems_nvdisk_sram_handlers
>>         const rtems_nvdisk_config rtems_nvdisk_configuration[] =
>>               block_size: 512,
>>               device_count: 1,
>>               devices: &rtems_sram_device_descriptor[0],
>>               flags: 0,
>>               info_level: 0
>>          * Create the SRAM Disk Driver entry.
>>         rtems_driver_address_table rtems_sram_ops = {
>>           initialization_entry: rtems_nvdisk_initialize,
>>             open_entry: rtems_blkdev_generic_open,
>>           close_entry: rtems_blkdev_generic_close,
>>             read_entry: rtems_blkdev_generic_read,
>>           write_entry: rtems_blkdev_generic_write,
>>             control_entry: rtems_blkdev_generic_ioctl
>>         void setup_sram_disk (int cold_boot)
>>           rtems_device_major_number major;
>>           rtems_status_code         sc;
>>         // settings
>>           rtems_sram_device_descriptor[0].base = (uint32_t *) malloc
>>         (256*1024);
>>         if (cold_boot)
>>         memset(rtems_sram_device_descriptor[0].base, 0xff,
>>         rtems_sram_device_descriptor[0].size );
>>           * Register the NV Disk driver.
>>             sc = rtems_io_register_driver (RTEMS_DRIVER_AUTO_MAJOR,
>>         &rtems_sram_ops, &major);
>>         if ( sc < 0 )
>>             printf("RTEMS Register IO driver failed\n");
>>         else
>>             printf("RTEMS register IO driver OK\n");
>>          * RFS on SRAM
>>         void mount_rfs_on_sram(int cold_boot)
>>           rtems_rfs_format_config config;
>>           rtems_status_code         rc;
>>           setup_sram_disk (cold_boot);
>>         // zero is a good set of defaults
>>           memset (&config, 0, sizeof (rtems_rfs_format_config));
>>         if (rtems_rfs_format (sram_driver, &config) < 0)
>>               printf("error: format of %s failed: %s\n", sram_driver,
>>         strerror (errno));
>>         else
>>             printf("RTEMS RFS format OK\n");
>>         if (mount_and_make_target_path(
>>               sram_driver,
>>               sram_path,
>>                 RTEMS_FILESYSTEM_TYPE_RFS,
>>               RTEMS_FILESYSTEM_READ_WRITE,
>>         NULL
>>             ) != 0)
>>                 printf("error: mount of %s to %s failed: %s\n",
>>         sram_driver, sram_path, strerror (errno));
>>         else
>>             printf("mount and make target path OK\n");
>>           rc = rtems_mkdir("sram/DB", S_IRWXU | S_IRGRP | S_IXGRP |
>>         S_IROTH | S_IXOTH);
>>         if ( rc < 0 )
>>             printf("rtems_mkdir failed\n");
>>         else
>>                printf("mkdir sdram/DB OK\n");
>>         rtems_task Init(
>>           rtems_task_argument ignored
>>           printf( "\n\n*** Starting NVRAM Disk Test ***\n");
>>         mount_rfs_on_sram(1);
>>         printf( "*** END OF TEST ***\n");
>>           exit( 0 );
>>         #define CONFIGURE_EXTRA_TASK_STACKS
>>         (CONFIGURE_MAXIMUM_TASKS * RTEMS_MINIMUM_STACK_SIZE)
>>         #define CONFIGURE_MAXIMUM_DRIVERS 6
>>         /* NOTICE: the clock driver is explicitly disabled */
>>         #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>         #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>         #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>>         #define CONFIGURE_MAXIMUM_TASKS 40 // TX MAX_THREAD
>>         #define CONFIGURE_MAXIMUM_TIMERS 40 // TX MAX_TIMER
>>         #define CONFIGURE_MAXIMUM_SEMAPHORES 40 // TX MAX_MUTEX
>>         #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 40 // TX MAX_MSG_QUEUE
>>         #define CONFIGURE_MAXIMUM_PARTITIONS 5
>>         #define CONFIGURE_MAXIMUM_REGIONS 5
>>         #define CONFIGURE_MAXIMUM_PORTS 0
>>         #define CONFIGURE_MAXIMUM_PERIODS 0
>>         #define CONFIGURE_MAXIMUM_BARRIERS 0
>>         #define CONFIGURE_MICROSECONDS_PER_TICK 10000 /* 10
>>         milliseconds */
>>         #define CONFIGURE_TICKS_PER_TIMESLICE 50 /* 50 milliseconds */
>>         #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>>         #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 2
>>         #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS 8
>>         #define CONFIGURE_SWAPOUT_TASK_PRIORITY 15
>>         #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>         #define CONFIGURE_FILESYSTEM_RFS
>>         #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
>>         #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>         #define CONFIGURE_INIT
>>         #include <rtems/confdefs.h>
>>         On Mar 18, 2013, at 2:35 PM, Matthew J Fletcher
>>         <amimjf at gmail.com <mailto:amimjf at gmail.com>> wrote:
>>>         Hi,
>>>         Alas the mkdir() is the first filesystem operation i am
>>>         doing. I am not sure if i can send attachments to the list
>>>         so i've cut and pasted the relivant functions below. I guess
>>>         the following would run on any BSP, its just a 256k block of
>>>         sram. If there is a BSP with enough memory the base pointer
>>>         for the filesystem could just be a big malloc().
>>>         ------------------- snip -------------------------
>>>         #define CONFIGURE_IDLE_TASK_BODY rtems_idle
>>>         #define CONFIGURE_EXTRA_TASK_STACKS (CONFIGURE_MAXIMUM_TASKS
>>>         MAX_THREAD
>>>         MAX_TIMER
>>>         MAX_MUTEX
>>>         MAX_MSG_QUEUE
>>>         milliseconds */
>>>         uint32_t rtems_flashdisk_configuration_size =1;
>>>         const char* flash_driver = "/dev/fdda";    //
>>>         RTEMS_FLASHDISK_DEVICE_BASE_NAME, 1st device
>>>         const char* flash_path = "/flash";
>>>         const char* sram_driver = "/dev/nvda"; //
>>>         #define FLASHDISK_SEGMENT_COUNT 8 /* 128*/    // Spansion
>>>         S29GL128S, 128Mbit part
>>>         #define FLASHDISK_SEGMENT_SIZE (128 * 1024)    // Spansion
>>>         S29GL128S, 128k sized sectors
>>>         #define FLASHDISK_BLOCK_SIZE 512
>>>         #define FLASHDISK_BLOCKS_PER_SEGMENT (FLASHDISK_SEGMENT_SIZE
>>>         / FLASHDISK_BLOCK_SIZE)
>>>         #define FLASHDISK_SIZE (FLASHDISK_SEGMENT_COUNT *
>>>         FLASHDISK_SEGMENT_SIZE)
>>>                 flags:  0,
>>>                 base:   0,
>>>                 size:   256 * 1024, // 256K (Adjust when ROM.ld,
>>>                 block_size:         512,
>>>                 device_count:       1,
>>>                 flags:              0,
>>>                 info_level:         0
>>>         int setup_sram_disk (int cold_boot)
>>>             // settings
>>>         rtems_sram_device_descriptor[0].base = (unsigned
>>>         long)eTalus_IMFS_start;
>>>             if (cold_boot)
>>>          * RFS on SRAM
>>>         sprintf(inital_print_buffer,"error: format of %s failed:
>>>         %s\n", sram_driver, strerror (errno));
>>>         UART0_SendStr(inital_print_buffer);
>>>                 sram_driver,
>>>                 sram_path,
>>>                 NULL
>>>               ) != 0)
>>>         sprintf(inital_print_buffer,"error: mount of %s to %s
>>>         failed: %s\n", sram_driver, sram_path, strerror (errno));
>>>         | S_IROTH | S_IXOTH);
>>>         ------------------- end ------------------------
>>>         On 18 March 2013 17:42, Joel Sherrill
>>>         <joel.sherrill at oarcorp.com
>>>         <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>             Is this reproducible with something you can share?
>>>             Looking at the source, I think this case is that you
>>>             filled the filesystem and there were no free blocks.
>>>             But I am looking at the head and not that familiar
>>>             with this filesystem.
>>>             --joel
>>>             On 3/18/2013 12:20 PM, Matthew J Fletcher wrote:
>>>                 Hi,
>>>                 I have an RFS filesystem using the nvram device, its
>>>                 formatted ok and mount_and_make_target_path() also
>>>                 worked ok. But attempting to mkdir() causes a really
>>>                 lowlevel issue.
>>>                 The callstack;
>>>                 rtems_rfs_block_map_find() at rtems-rfs-block.c:246
>>>                 0x81198bd8
>>>                 rtems_rfs_block_map_next_block() at
>>>                 rtems-rfs-block.c:353 0x81198d1e
>>>                 rtems_rfs_dir_lookup_ino() at rtems-rfs-dir.c:204
>>>                 0x8119951c
>>>                 rtems_rfs_rtems_eval_for_make() at
>>>                 rtems-rfs-rtems.c:440 0x8118e142
>>>                 IMFS_evaluate_for_make() at imfs_eval.c:435 0x81190718
>>>                 mknod() at mknod.c:64 0x81183d5c
>>>                 mkdir() at mkdir.c:29 0x81183cf0
>>>                 build() at rtems_mkdir.c:101 0x811843a0
>>>                 rtems_mkdir() at rtems_mkdir.c:136 0x811843a0
>>>                 the rtems_rfs_block_pos_block_past_end macro is
>>>                 failing and causing the return of ENXIO.
>>>                 The two arguments to the macro are;
>>>                 bpos->bno = 1
>>>                 bpos->boff = 0
>>>                 bpos->block = 0
>>>                 map->size->count = 1
>>>                 map->size->offset = 0
>>>                 Which seems to me the cause of ENXIO being returned,
>>>                 but i dont know how my BSP could affect this.
>>>                 Do people use RFS in production systems ? i am using
>>>                 the 4.10.2 sources.
>>>                 regards
>>>                 Matthew J Fletcher
>>>             Joel Sherrill, Ph.D.     Director of Research & Development
>>>             <mailto:joel.sherrill at OARcorp.com>        On-Line
>>>             Applications Research
>>>             Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>             Support Available      (256) 722-9985
>>>         regards
>>>         Matthew J Fletcher
>>>         _______________________________________________
>>>         rtems-users mailing list
>>>         rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>>         http://www.rtems.org/mailman/listinfo/rtems-users
> regards
> Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130320/e0bff8bc/attachment-0001.html>
