Updated Raspberry Pi instructions and created RTEMS app framework
Mathew Benson mathew.benson at gmail.com
Wed May 8 02:14:44 UTC 2013
Excellent.  Do you have a detailed manual for using CFS on RTEMS on RPI?  I've heard some good things about CFS.  Figured I might take a look.
Sent from my iPhone
On May 7, 2013, at 8:20 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi,
> I have updated my Raspberry Pi RTEMS instructions here:
> http://alanstechnotes.blogspot.com/2013/03/rtems-on-raspberry-pi.html
> But probably of more interest to RTEMS users is my RTEMS App framework, which is here:
> http://github.com/alanc98/rki
> The RKI or RTEMS Kernel Image is my simple app framework that lets you get a fairly complicated RTEMS app up and running quickly. It supports a RAM disk, NVRAM disks, shell startup with init script, network setup, and has some example shell commands such as the whetstone and dhrystone benchmarks.
> The project has makefiles for sparc-rtems4.11 / sis and arm-rtems4.11 / raspberrypi
> It may run on RTEMS 4.10, but I recently updated the RAM disk init code for 4.11 and have not tried it on 4.10 yet.
> Alan
> rtems-users mailing list
> rtems-users at rtems.org
