Unused Variable Error while building binutil-2.20.1
manish jain
manish8886 at gmail.com
Tue May 21 21:37:10 UTC 2013
Hi,
As I am working with leon3 and Gaisler is currently using rtems4.10 bsp
therefore I am trying to build rtems4.10. I was able to build rtems4.11
succesfully.
But, now as I build following binutil packages:
"ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10/a/[image: File:]
binutils-2.20.1.tar.bz2<ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10/binutils-2.20.1.tar.bz2>"
and
the patch
"[image: File:]binutils-2.20.1-rtems4.10-20130320.diff<ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10/binutils-2.20.1-rtems4.10-20130320.diff>".(last
updated on 03/20/2013)
I am facing various "unused variable compile error".
For example:
"rtems-4.10/binutils-2.20.1/bfd/verilog.c:225:15: error: variable ‘address’
set but not used [-Werror=unused-but-set-variable]"
I have tried to change these files(by removing these variable). But it
seems this error is spreading at many place.
I checked with my previous
"binutils-2.23.1.tar.bz2<ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10/binutils-2.20.1.tar.bz2>"(it
was for rtems4.11). . It was building fine and those above variables were
not present in this packages.
Am I using correct binutil package for rtems-4.10?
Thanks
Manish
URL: <http://lists.rtems.org/pipermail/users/attachments/20130521/08b5a0fc/attachment.html>
