RTEMS-4.10.2 Building Error
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 21 12:59:51 UTC 2013
On 5/21/2013 7:49 AM, Gedare Bloom wrote:
> Maybe some problem with your sparc-rtems4.11-binutils? What guide are
> you following for building your project?
> You might like to check out the RTEMS source builder [1] [2]. It has
> known-to-work scripts for building RTEMS tools and RTEMS itself for
> many different hosts.
Maybe I have a disconnect but the subject says 4.10.2 and the tools
are 4.11. Did Manish switch to the git master?
> -Gedare
> [1] http://git.rtems.org/rtems-source-builder/
> [2] http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html
> On Tue, May 21, 2013 at 12:05 AM, manish jain <manish8886 at gmail.com> wrote:
>> Hi All,
>> I was able to build RTEMS-4.10.2 successfully last time. But due to some
>> reason when I tried to build again, I am getting following "Assembler
>> Errors". I have checked "sparc-rtems4.11-gcc", it is still working fine with
>> ordinary ".c"files. Any input what might be the reason for these errors?
>> configure:3440: sparc-rtems4.11-gcc -mcpu=cypress -O2 -g conftest.c >&5
>> /tmp/ccHERiZW.s: Assembler messages:
>> /tmp/ccHERiZW.s:8: Error: unrecognized symbol type ""
>> /tmp/ccHERiZW.s:9: Error: unknown pseudo-op: `.proc'
>> /tmp/ccHERiZW.s:16: Error: bad register name `%o7+8'
>> /tmp/ccHERiZW.s:17: Error: bad register name `%o0'
>> /tmp/ccHERiZW.s:25: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:26: Error: unknown pseudo-op: `.uahalf'
>> /tmp/ccHERiZW.s:27: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:30: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:32: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:33: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:34: Error: unknown pseudo-op: `.uaword'
>> /tmp/ccHERiZW.s:35: Error: unknown pseudo-op: `.uaword'
>> configure:3487: error: in
>> `/home/manish/tools/b-rtems/sparc-rtems4.11/c/sis':
>> configure:3489: error: C compiler cannot create executables
>> Thanks
>> Manish
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
