Errors in PSIM
Thu May 2 01:20:19 UTC 2013
You tell the partitions where to start, so just give the second partition
the right address. You have to be sure the memory you use is available both
in the hw as real memory and also not used for other purposes. Probably you
can malloc all the memory you need at startup time and pass pointers into
the allocated buffer to partition create.
-Gedare
On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
> Hmmm. The 'Testing Task' does not have a while(1) loop and I'm not
> deleting it. Could that be it? *<- Yup, that's it. Just tested. Can you
> please explain how did you arrive at this conclusion?*
> I'm referring to the MPC5200B board. You can see the manual in the
> following link:
> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
> Now, mentioning the partitions and memory addresses. I'm not quite sure if
> I'm incrementing addresses correctly. I do want to create a partition right
> next where the other one finishes.
> So, if starting address is 0x10000, the next partition will start at
> 0x10000 + previousPartitionSize.
> Does this make sense?
> Thanks.
> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>>  It could be another task exiting. You mentioned loading code.
>> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
>>  Ok.
>>  1) The Init task is already deleting itself after loading the other
>> tasks. Do I have to do something else?
>>  2) The memory for partitions came from the board data sheet. I based
>> myself on the addresses mentioned there and followed upon. I was creating
>> the first one starting at 0x10000 and incrementing from that according to
>> each partition's size.
>>  Can you help me set these 2 things up? I'm not really sure how to deal
>> with that memory issue and the internal error as well.
>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>>>  That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds
>>>  I'm also getting the following error when I uncomment the function
>>> that creates 10 partitions to be used by my application:
>>>  *core_find_mapping() - access to unmaped address, attach a default map
>>> to handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000 cia=0x1028c
>>> Can you please help?
>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>  I am using psim-gdb testing my own application, it's not an RTEMS
>>>> example.
>>>>  I managed to break right on it, and it stops at:
>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>  Signature is the following:
>>>>  the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>> is_internal=is_internal at entry=true,
>>>>     the_error=the_error at entry=5)
>>>>  I have no clue of what it can be. Do you have any idea?
>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <
>>>> Joel.Sherrill at oarcorp.com> wrote:
>>>>>  Where is the file events.c?
>>>>> Break at the fault handler printing that.
>>>>> Does this happen with any rtems provided examples?
>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>   Hi everyone,
>>>>>  I was just testing my application using PSIM and it is returning the
>>>>> following lines, right after starting a Task:
>>>>>  *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
>>>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>>>>  Has anybody experienced this before?
>>>>>  Thanks.
>>>>> Cassio
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/a805f6a8/attachment-0001.html>
