Errors in PSIM
Binkowski, Cassio
cassioiks at gmail.com
Thu May 2 02:00:03 UTC 2013
I know I'm missing out on something. It's probably because of the memory
addresses and maybe a custom config is required on that file mentioned by
Joel (
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds).
I have never dealt with this before and will need some assistance.
On Wed, May 1, 2013 at 10:35 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
> That may be one solution.
> @Joel: Thank you so much for the detailed explanation.
> One thing that would be great is that if we could somehow condense all
> this information exchanged in the mailing list into the
> Wiki/Manuals/Doxygen.
> For example, I am now getting another exception, I'm just pasting some of
> it, because it's huge:
> *Suspending faulting task (0x0A010003)*
> *Exception handler called for exception 7 (0x7)*
> *Too many stack frames (stack possibly corrupted), giving up...*
> *Suspending faulting task (0x0A010004)*
> It's given at the creation of the 7th partition when function *
> _API_extensions_Run_postswitch()* is executed.
> How can I start searching for it? I don't know what to look for inside
> inter.h.
> Best regards
> Cassio
> On Wed, May 1, 2013 at 10:18 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>> You tell the partitions where to start, so just give the second partition
>> the right address. You have to be sure the memory you use is available both
>> in the hw as real memory and also not used for other purposes. Probably you
>> can malloc all the memory you need at startup time and pass pointers into
>> the allocated buffer to partition create.
>> -Gedare
>> On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>>> Hmmm. The 'Testing Task' does not have a while(1) loop and I'm not
>>> deleting it. Could that be it? *<- Yup, that's it. Just tested. Can you
>>> please explain how did you arrive at this conclusion?*
>>> I'm referring to the MPC5200B board. You can see the manual in the
>>> following link:
>>> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
>>> Now, mentioning the partitions and memory addresses. I'm not quite sure
>>> if I'm incrementing addresses correctly. I do want to create a partition
>>> right next where the other one finishes.
>>> So, if starting address is 0x10000, the next partition will start at
>>> 0x10000 + previousPartitionSize.
>>> Does this make sense?
>>> Thanks.
>>> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
>>> > wrote:
>>>> It could be another task exiting. You mentioned loading code.
>>>> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
>>>> Ok.
>>>> 1) The Init task is already deleting itself after loading the other
>>>> tasks. Do I have to do something else?
>>>> 2) The memory for partitions came from the board data sheet. I based
>>>> myself on the addresses mentioned there and followed upon. I was creating
>>>> the first one starting at 0x10000 and incrementing from that according to
>>>> each partition's size.
>>>> Can you help me set these 2 things up? I'm not really sure how to
>>>> deal with that memory issue and the internal error as well.
>>>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <
>>>> Joel.Sherrill at oarcorp.com> wrote:
>>>>> That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>>>>> I'm also getting the following error when I uncomment the function
>>>>> that creates 10 partitions to be used by my application:
>>>>> *core_find_mapping() - access to unmaped address, attach a default
>>>>> map to handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000
>>>>> cia=0x1028c*
>>>>> Can you please help?
>>>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <cassioiks at gmail.com
>>>>> > wrote:
>>>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>>> I am using psim-gdb testing my own application, it's not an RTEMS
>>>>>> example.
>>>>>> I managed to break right on it, and it stops at:
>>>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>>> Signature is the following:
>>>>>> the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>>>> is_internal=is_internal at entry=true,
>>>>>> the_error=the_error at entry=5)
>>>>>> I have no clue of what it can be. Do you have any idea?
>>>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <
>>>>>>> Where is the file events.c?
>>>>>>> Break at the fault handler printing that.
>>>>>>> Does this happen with any rtems provided examples?
>>>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>>> Hi everyone,
>>>>>>> I was just testing my application using PSIM and it is returning
>>>>>>> the following lines, right after starting a Task:
>>>>>>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
>>>>>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>>>>>> Has anybody experienced this before?
>>>>>>> Thanks.
>>>>>>> Cassio
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/3f604080/attachment-0001.html>
