Errors in PSIM
Binkowski, Cassio
cassioiks at gmail.com
Mon May 6 01:01:27 UTC 2013
Hi Gedare,
Can you please explain where/how in linkcmds I should be touching and how
to let the bps know about the change?
I'm very new to this.
Also, how do I calculate how much space RTEMS is taking so I know the
address to start creating the partitions?
Thanks!
On Sun, May 5, 2013 at 9:40 PM, Gedare Bloom <gedare at gwmail.gwu.edu> wrote:
> You probably need to modify the bsp linkcmds file, or just malloc a large
> chunk. The bsp may need to know about the extra memory in either case, so
> check out the linkcmds.
> -Gedare
> On May 5, 2013 2:46 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>> Thanks Joel.
>> I have modified it to be with 32 MB of RAM.
>> /openprom/options/oea-memory-size 33554432
>> Right now my doubt is the following:
>> From psim.in or other resources, how can I know at which address I can
>> start creating the partitions and make sure it won't give me an 'unmapped
>> address' error again?
>> Thanks.
>> On Thu, May 2, 2013 at 12:06 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> > wrote:
>>> I don't know where this all ended yesterday.
>>> On 5/1/2013 9:00 PM, Binkowski, Cassio wrote:
>>> I know I'm missing out on something. It's probably because of the memory
>>> addresses and maybe a custom config is required on that file mentioned by
>>> Joel (
>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds).
>>> I have never dealt with this before and will need some assistance.
>>> You could modify the device tree created by psim/psim-gdb to add
>>> more RAM or a second bank of RAM after the first 16 MB that the
>>> linkcmds knows about. This is in psim.in:
>>> /openprom/options/oea-memory-size 16777216
>>> The bottom line is that you are reading the mpc5200 PowerPC manual for
>>> addresses and that does not have any correlation to the memory map of
>>> the "psim board" as defined by the device-tree.
>>> 0x10000 is 64k which is in use by the program or RTEMS.
>>> 0x100000 is 1MB and is also in use by the program or RTEMS.
>>> 0x1000000 is outside the memory map.
>>> --joel
>>> On Wed, May 1, 2013 at 10:35 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
>>>> That may be one solution.
>>>> @Joel: Thank you so much for the detailed explanation.
>>>> One thing that would be great is that if we could somehow condense all
>>>> this information exchanged in the mailing list into the
>>>> Wiki/Manuals/Doxygen.
>>>> For example, I am now getting another exception, I'm just pasting
>>>> some of it, because it's huge:
>>>> *Suspending faulting task (0x0A010003)*
>>>> *Exception handler called for exception 7 (0x7)*
>>>> *Too many stack frames (stack possibly corrupted), giving up...*
>>>> *Suspending faulting task (0x0A010004)*
>>>> It's given at the creation of the 7th partition when function *
>>>> _API_extensions_Run_postswitch()* is executed.
>>>> How can I start searching for it? I don't know what to look for
>>>> inside inter.h.
>>>> Best regards
>>>> Cassio
>>>> On Wed, May 1, 2013 at 10:18 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>>>>> You tell the partitions where to start, so just give the second
>>>>> partition the right address. You have to be sure the memory you use is
>>>>> available both in the hw as real memory and also not used for other
>>>>> purposes. Probably you can malloc all the memory you need at startup time
>>>>> and pass pointers into the allocated buffer to partition create.
>>>>> -Gedare
>>>>> On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>> wrote:
>>>>>> Hmmm. The 'Testing Task' does not have a while(1) loop and I'm not
>>>>>> deleting it. Could that be it? *<- Yup, that's it. Just tested. Can
>>>>>> you please explain how did you arrive at this conclusion?*
>>>>>> I'm referring to the MPC5200B board. You can see the manual in the
>>>>>> following link:
>>>>>> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
>>>>>> Now, mentioning the partitions and memory addresses. I'm not quite
>>>>>> sure if I'm incrementing addresses correctly. I do want to create a
>>>>>> partition right next where the other one finishes.
>>>>>> So, if starting address is 0x10000, the next partition will start at
>>>>>> 0x10000 + previousPartitionSize.
>>>>>> Does this make sense?
>>>>>> Thanks.
>>>>>> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <
>>>>>> Joel.Sherrill at oarcorp.com> wrote:
>>>>>>> It could be another task exiting. You mentioned loading code.
>>>>>>> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
>>>>>>> Ok.
>>>>>>> 1) The Init task is already deleting itself after loading the
>>>>>>> other tasks. Do I have to do something else?
>>>>>>> 2) The memory for partitions came from the board data sheet. I
>>>>>>> based myself on the addresses mentioned there and followed upon. I was
>>>>>>> creating the first one starting at 0x10000 and incrementing from that
>>>>>>> according to each partition's size.
>>>>>>> Can you help me set these 2 things up? I'm not really sure how to
>>>>>>> deal with that memory issue and the internal error as well.
>>>>>>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <
>>>>>>>> That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>>>>>>>> I'm also getting the following error when I uncomment the
>>>>>>>> function that creates 10 partitions to be used by my application:
>>>>>>>> *core_find_mapping() - access to unmaped address, attach a
>>>>>>>> default map to handle this - addr=0x1000d2c nr_bytes=0x4
>>>>>>>> processor=0xa8e5000 cia=0x1028c*
>>>>>>>> Can you please help?
>>>>>>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <
>>>>>>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>>>>>> I am using psim-gdb testing my own application, it's not an
>>>>>>>>> RTEMS example.
>>>>>>>>> I managed to break right on it, and it stops at:
>>>>>>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>>>>>> Signature is the following:
>>>>>>>>> the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>>>>>>> is_internal=is_internal at entry=true,
>>>>>>>>> the_error=the_error at entry=5)
>>>>>>>>> I have no clue of what it can be. Do you have any idea?
>>>>>>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <
>>>>>>>>>> Where is the file events.c?
>>>>>>>>>> Break at the fault handler printing that.
>>>>>>>>>> Does this happen with any rtems provided examples?
>>>>>>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>>>>>> Hi everyone,
>>>>>>>>>> I was just testing my application using PSIM and it is
>>>>>>>>>> returning the following lines, right after starting a Task:
>>>>>>>>>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC
>>>>>>>>>> ERROR 5*
>>>>>>>>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>>>>>>>>> Has anybody experienced this before?
>>>>>>>>>> Thanks.
>>>>>>>>>> Cassio
>>>>>> _______________________________________________
>>>>>> rtems-users mailing list
>>>>>> rtems-users at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Joel Sherrill, Ph.D. Director of Research & Development joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130505/8f956951/attachment-0001.html>
