Errors in PSIM
    Gedare Bloom
    gedare at rtems.org
    Mon May  6 02:26:50 UTC 2013
You can look for some tutorials on ld scripts. This is an area of rtems
that lacks good documentation.
The only way to know what memory you can use outside of rtems is to inspect
the linkcmds. In your case though you might be able to just point at the 16
MB base address, since psim bsp does not expect to use that much ram...
On May 5, 2013 9:01 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
> Hi Gedare,
> Can you please explain where/how in linkcmds I should be touching and how
> to let the bps know about the change?
> I'm very new to this.
> Also, how do I calculate how much space RTEMS is taking so I know the
> address to start creating the partitions?
> Thanks!
> On Sun, May 5, 2013 at 9:40 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>> You probably need to modify the bsp linkcmds file, or just malloc a large
>> chunk. The bsp may need to know about the extra memory in either case, so
>> check out the linkcmds.
>> -Gedare
>> On May 5, 2013 2:46 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>>> Thanks Joel.
>>> I have modified it to be with 32 MB of RAM.
>>> /openprom/options/oea-memory-size 33554432
>>> Right now my doubt is the following:
>>> From psim.in or other resources, how can I know at which address I can
>>> start creating the partitions and make sure it won't give me an 'unmapped
>>> address' error again?
>>> Thanks.
>>> On Thu, May 2, 2013 at 12:06 PM, Joel Sherrill <
>>> joel.sherrill at oarcorp.com> wrote:
>>>>  I don't know where this all ended yesterday.
>>>> On 5/1/2013 9:00 PM, Binkowski, Cassio wrote:
>>>> I know I'm missing out on something. It's probably because of the
>>>> memory addresses and maybe a custom config is required on that file
>>>> mentioned by Joel (
>>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds).
>>>> I have never dealt with this before and will need some assistance.
>>>>  You could modify the device tree created by psim/psim-gdb to add
>>>> more RAM or a second bank of RAM after the first 16 MB that the
>>>> linkcmds knows about.  This is in psim.in:
>>>> /openprom/options/oea-memory-size 16777216
>>>> The bottom line is that you are reading the mpc5200 PowerPC manual for
>>>> addresses and that does not have any correlation to the memory map of
>>>> the "psim board" as defined by the device-tree.
>>>> 0x10000 is 64k which is in use by the program or RTEMS.
>>>> 0x100000 is 1MB and is also in use by the program or RTEMS.
>>>> 0x1000000 is outside the memory map.
>>>> --joel
>>>> On Wed, May 1, 2013 at 10:35 PM, Binkowski, Cassio <cassioiks at gmail.com
>>>> > wrote:
>>>>> That may be one solution.
>>>>>  @Joel: Thank you so much for the detailed explanation.
>>>>> One thing that would be great is that if we could somehow condense all
>>>>> this information exchanged in the mailing list into the
>>>>> Wiki/Manuals/Doxygen.
>>>>>  For example, I am now getting another exception, I'm just pasting
>>>>> some of it, because it's huge:
>>>>>  *Suspending faulting task (0x0A010003)*
>>>>> *Exception handler called for exception 7 (0x7)*
>>>>>  *Too many stack frames (stack possibly corrupted), giving up...*
>>>>> *Suspending faulting task (0x0A010004)*
>>>>> It's given at the creation of the 7th partition when function *
>>>>> _API_extensions_Run_postswitch()* is executed.
>>>>>  How can I start searching for it? I don't know what to look for
>>>>> inside inter.h.
>>>>>  Best regards
>>>>>  Cassio
>>>>>  On Wed, May 1, 2013 at 10:18 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>>>>>> You tell the partitions where to start, so just give the second
>>>>>> partition the right address. You have to be sure the memory you use is
>>>>>> available both in the hw as real memory and also not used for other
>>>>>> purposes. Probably you can malloc all the memory you need at startup time
>>>>>> and pass pointers into the allocated buffer to partition create.
>>>>>> -Gedare
>>>>>>  On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>>> wrote:
>>>>>>>  Hmmm. The 'Testing Task' does not have a while(1) loop and I'm not
>>>>>>> deleting it. Could that be it? *<- Yup, that's it. Just tested. Can
>>>>>>> you please explain how did you arrive at this conclusion?*
>>>>>>>  I'm referring to the MPC5200B board. You can see the manual in the
>>>>>>> following link:
>>>>>>> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
>>>>>>>  Now, mentioning the partitions and memory addresses. I'm not quite
>>>>>>> sure if I'm incrementing addresses correctly. I do want to create a
>>>>>>> partition right next where the other one finishes.
>>>>>>> So, if starting address is 0x10000, the next partition will start at
>>>>>>> 0x10000 + previousPartitionSize.
>>>>>>> Does this make sense?
>>>>>>>  Thanks.
>>>>>>> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <
>>>>>>> Joel.Sherrill at oarcorp.com> wrote:
>>>>>>>>  It could be another task exiting. You mentioned loading code.
>>>>>>>> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
>>>>>>>>   Ok.
>>>>>>>>  1) The Init task is already deleting itself after loading the
>>>>>>>> other tasks. Do I have to do something else?
>>>>>>>>  2) The memory for partitions came from the board data sheet. I
>>>>>>>> based myself on the addresses mentioned there and followed upon. I was
>>>>>>>> creating the first one starting at 0x10000 and incrementing from that
>>>>>>>> according to each partition's size.
>>>>>>>>  Can you help me set these 2 things up? I'm not really sure how to
>>>>>>>> deal with that memory issue and the internal error as well.
>>>>>>>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <
>>>>>>>>>  That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>>>>>>>>>  I'm also getting the following error when I uncomment the
>>>>>>>>> function that creates 10 partitions to be used by my application:
>>>>>>>>>  *core_find_mapping() - access to unmaped address, attach a
>>>>>>>>> default map to handle this - addr=0x1000d2c nr_bytes=0x4
>>>>>>>>> processor=0xa8e5000 cia=0x1028c*
>>>>>>>>> Can you please help?
>>>>>>>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <
>>>>>>>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>>>>>>>  I am using psim-gdb testing my own application, it's not an
>>>>>>>>>> RTEMS example.
>>>>>>>>>>  I managed to break right on it, and it stops at:
>>>>>>>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>>>>>>>  Signature is the following:
>>>>>>>>>>  the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>>>>>>>> is_internal=is_internal at entry=true,
>>>>>>>>>>     the_error=the_error at entry=5)
>>>>>>>>>>  I have no clue of what it can be. Do you have any idea?
>>>>>>>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <
>>>>>>>>>>>  Where is the file events.c?
>>>>>>>>>>> Break at the fault handler printing that.
>>>>>>>>>>> Does this happen with any rtems provided examples?
>>>>>>>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>>>>>>>   Hi everyone,
>>>>>>>>>>>  I was just testing my application using PSIM and it is
>>>>>>>>>>> returning the following lines, right after starting a Task:
>>>>>>>>>>>  *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC
>>>>>>>>>>> ERROR 5*
>>>>>>>>>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>>>>>>>>>>  Has anybody experienced this before?
>>>>>>>>>>>  Thanks.
>>>>>>>>>>> Cassio
>>>>>>>  _______________________________________________
>>>>>>> rtems-users mailing list
>>>>>>> rtems-users at rtems.org
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>> Joel Sherrill, Ph.D.             Director of Research & Development joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130505/5b05fd3d/attachment-0001.html>
