Errors in PSIM
Binkowski, Cassio cassioiks at gmail.com
Tue May 7 12:10:45 UTC 2013
Thanks for the info, Gedare.
Just an FYI now. I found out how to properly increment memory in psim. You
need to do it right on psim or psim-gdb script, on directive: *
/openprom/options/oea-memory-size *
That's where one should do it.
Thanks for the support.
Cassio
On Mon, May 6, 2013 at 10:18 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Ah, sounds like an issue with the mmu. You may need to investigate how the
> memory map is implemented in psim. It might use a variable defined in the
> linker script.
> RTEMS can estimate the memory usage with spsize test case... usually the
> workspace allocation size is well known, and the rest of unused ram goes to
> heap. But this depends on the linkcmds of the bsp.
>  On May 6, 2013 8:55 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>> So there is now way to know how much memory RTEMS is actually using?
>> Also, I have modified psim.in to be with 32mb of RAM:
>> /openprom/options/oea-memory-size 33554432
>> However, when I try to create a partition with starting address 0x1000000
>> (10 MB) it says the address is not mapped. How can that be?
>> On Sun, May 5, 2013 at 11:39 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
>> > wrote:
>>>  The linker script format is defined by binutils. RTEMS bsps need enough symbols to define the work area and starting stack.
>>> Since the linker script has 16mb in it, that is all the RTEMS application can know about. Anything beyond that 16mb is free for you to use as you like.
>>>  You can look for some tutorials on ld scripts. This is an area of
>>> rtems that lacks good documentation.
>>> The only way to know what memory you can use outside of rtems is to
>>> inspect the linkcmds. In your case though you might be able to just point
>>> at the 16 MB base address, since psim bsp does not expect to use that much
>>> ram...
>>> On May 5, 2013 9:01 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>>>> Hi Gedare,
>>>>  Can you please explain where/how in linkcmds I should be touching and
>>>> how to let the bps know about the change?
>>>> I'm very new to this.
>>>>  Also, how do I calculate how much space RTEMS is taking so I know the
>>>> address to start creating the partitions?
>>>>  Thanks!
>>>> On Sun, May 5, 2013 at 9:40 PM, Gedare Bloom <gedare at gwmail.gwu.edu>wrote:
>>>>> You probably need to modify the bsp linkcmds file, or just malloc a
>>>>> large chunk. The bsp may need to know about the extra memory in either
>>>>> case, so check out the linkcmds.
>>>>> -Gedare
>>>>>  On May 5, 2013 2:46 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>> wrote:
>>>>>> Thanks Joel.
>>>>>>  I have modified it to be with 32 MB of RAM.
>>>>>>  Right now my doubt is the following:
>>>>>>  From psim.in or other resources, how can I know at which address I
>>>>>> can start creating the partitions and make sure it won't give me an
>>>>>> 'unmapped address' error again?
>>>>>>  Thanks.
>>>>>> On Thu, May 2, 2013 at 12:06 PM, Joel Sherrill <
>>>>>> joel.sherrill at oarcorp.com> wrote:
>>>>>>>  I don't know where this all ended yesterday.
>>>>>>> On 5/1/2013 9:00 PM, Binkowski, Cassio wrote:
>>>>>>> I know I'm missing out on something. It's probably because of the
>>>>>>> memory addresses and maybe a custom config is required on that file
>>>>>>> mentioned by Joel (
>>>>>>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds).
>>>>>>> I have never dealt with this before and will need some assistance.
>>>>>>>   You could modify the device tree created by psim/psim-gdb to add
>>>>>>> more RAM or a second bank of RAM after the first 16 MB that the
>>>>>>> linkcmds knows about.  This is in psim.in:
>>>>>>> /openprom/options/oea-memory-size 16777216
>>>>>>> The bottom line is that you are reading the mpc5200 PowerPC manual
>>>>>>> for
>>>>>>> addresses and that does not have any correlation to the memory map of
>>>>>>> the "psim board" as defined by the device-tree.
>>>>>>> 0x10000 is 64k which is in use by the program or RTEMS.
>>>>>>> 0x100000 is 1MB and is also in use by the program or RTEMS.
>>>>>>> 0x1000000 is outside the memory map.
>>>>>>> --joel
>>>>>>> On Wed, May 1, 2013 at 10:35 PM, Binkowski, Cassio <
>>>>>>>> That may be one solution.
>>>>>>>>  @Joel: Thank you so much for the detailed explanation.
>>>>>>>> One thing that would be great is that if we could somehow condense
>>>>>>>> all this information exchanged in the mailing list into the
>>>>>>>> Wiki/Manuals/Doxygen.
>>>>>>>>  For example, I am now getting another exception, I'm just pasting
>>>>>>>> some of it, because it's huge:
>>>>>>>>  *Suspending faulting task (0x0A010003)*
>>>>>>>> *Exception handler called for exception 7 (0x7)*
>>>>>>>>  *Too many stack frames (stack possibly corrupted), giving up...*
>>>>>>>> *Suspending faulting task (0x0A010004)*
>>>>>>>> It's given at the creation of the 7th partition when function *
>>>>>>>> _API_extensions_Run_postswitch()* is executed.
>>>>>>>>  How can I start searching for it? I don't know what to look for
>>>>>>>> inside inter.h.
>>>>>>>>  Best regards
>>>>>>>>  Cassio
>>>>>>>> On Wed, May 1, 2013 at 10:18 PM, Gedare Bloom <
>>>>>>>> gedare at gwmail.gwu.edu> wrote:
>>>>>>>>> You tell the partitions where to start, so just give the second
>>>>>>>>> partition the right address. You have to be sure the memory you use is
>>>>>>>>> available both in the hw as real memory and also not used for other
>>>>>>>>> purposes. Probably you can malloc all the memory you need at startup time
>>>>>>>>> and pass pointers into the allocated buffer to partition create.
>>>>>>>>> -Gedare
>>>>>>>>>  On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>>  Hmmm. The 'Testing Task' does not have a while(1) loop and I'm
>>>>>>>>>> not deleting it. Could that be it? *<- Yup, that's it. Just
>>>>>>>>>> tested. Can you please explain how did you arrive at this conclusion?
>>>>>>>>>>  I'm referring to the MPC5200B board. You can see the manual in
>>>>>>>>>> the following link:
>>>>>>>>>> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
>>>>>>>>>>  Now, mentioning the partitions and memory addresses. I'm not
>>>>>>>>>> quite sure if I'm incrementing addresses correctly. I do want to create a
>>>>>>>>>> partition right next where the other one finishes.
>>>>>>>>>> So, if starting address is 0x10000, the next partition will start
>>>>>>>>>> at 0x10000 + previousPartitionSize.
>>>>>>>>>> Does this make sense?
>>>>>>>>>>  Thanks.
>>>>>>>>>> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <
>>>>>>>>>> Joel.Sherrill at oarcorp.com> wrote:
>>>>>>>>>>>  It could be another task exiting. You mentioned loading code.
>>>>>>>>>>> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
>>>>>>>>>>>   Ok.
>>>>>>>>>>>  1) The Init task is already deleting itself after loading the
>>>>>>>>>>> other tasks. Do I have to do something else?
>>>>>>>>>>>  2) The memory for partitions came from the board data sheet. I
>>>>>>>>>>> based myself on the addresses mentioned there and followed upon. I was
>>>>>>>>>>> creating the first one starting at 0x10000 and incrementing from that
>>>>>>>>>>> according to each partition's size.
>>>>>>>>>>>  Can you help me set these 2 things up? I'm not really sure how
>>>>>>>>>>> to deal with that memory issue and the internal error as well.
>>>>>>>>>>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <
>>>>>>>>>>>>  That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>>>>>>>>>>>>  I'm also getting the following error when I uncomment the
>>>>>>>>>>>> function that creates 10 partitions to be used by my application:
>>>>>>>>>>>>  *core_find_mapping() - access to unmaped address, attach a
>>>>>>>>>>>> default map to handle this - addr=0x1000d2c nr_bytes=0x4
>>>>>>>>>>>> processor=0xa8e5000 cia=0x1028c*
>>>>>>>>>>>> Can you please help?
>>>>>>>>>>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <
>>>>>>>>>>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>>>>>>>>>>  I am using psim-gdb testing my own application, it's not an
>>>>>>>>>>>>> RTEMS example.
>>>>>>>>>>>>>  I managed to break right on it, and it stops at:
>>>>>>>>>>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>>>>>>>>>>  Signature is the following:
>>>>>>>>>>>>>  the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>>>>>>>>>>> is_internal=is_internal at entry=true,
>>>>>>>>>>>>>     the_error=the_error at entry=5)
>>>>>>>>>>>>>  I have no clue of what it can be. Do you have any idea?
>>>>>>>>>>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <
>>>>>>>>>>>>>>  Where is the file events.c?
>>>>>>>>>>>>>> Break at the fault handler printing that.
>>>>>>>>>>>>>> Does this happen with any rtems provided examples?
>>>>>>>>>>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>>>>>>>>>>   Hi everyone,
>>>>>>>>>>>>>>  I was just testing my application using PSIM and it is
>>>>>>>>>>>>>> returning the following lines, right after starting a Task:
>>>>>>>>>>>>>>  *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC
>>>>>>>>>>>>>> ERROR 5*
>>>>>>>>>>>>>> *events.c:404: assertion failed - events->time_from_event > 0
>>>>>>>>>>>>>>  Has anybody experienced this before?
>>>>>>>>>>>>>>  Thanks.
>>>>>>>>>>>>>> Cassio
>>>>>>>>>>  _______________________________________________
>>>>>>>>>> rtems-users mailing list
>>>>>>>>>> rtems-users at rtems.org
>>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>>> Joel Sherrill, Ph.D.             Director of Research & Development joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>>>> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130507/18713d29/attachment-0001.html>
