Errors in PSIM
Gedare Bloom
gedare at rtems.org
Tue May 7 13:02:42 UTC 2013
Hm. That sounds like a small bug in the psim script setup. Probably it
is ignoring things in psim.in that are coded into the psim scripts.
-Gedare
On Tue, May 7, 2013 at 8:10 AM, Binkowski, Cassio <cassioiks at gmail.com> wrote:
> Thanks for the info, Gedare.
> Just an FYI now. I found out how to properly increment memory in psim. You
> need to do it right on psim or psim-gdb script, on directive:
> /openprom/options/oea-memory-size
> That's where one should do it.
> Thanks for the support.
> Cassio
> On Mon, May 6, 2013 at 10:18 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Ah, sounds like an issue with the mmu. You may need to investigate how the
>> memory map is implemented in psim. It might use a variable defined in the
>> linker script.
>> RTEMS can estimate the memory usage with spsize test case... usually the
>> workspace allocation size is well known, and the rest of unused ram goes to
>> heap. But this depends on the linkcmds of the bsp.
>> On May 6, 2013 8:55 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>>> So there is now way to know how much memory RTEMS is actually using?
>>> Also, I have modified psim.in to be with 32mb of RAM:
>>> /openprom/options/oea-memory-size 33554432
>>> However, when I try to create a partition with starting address 0x1000000
>>> (10 MB) it says the address is not mapped. How can that be?
>>> On Sun, May 5, 2013 at 11:39 PM, Joel Sherrill
>>> <Joel.Sherrill at oarcorp.com> wrote:
>>>> The linker script format is defined by binutils. RTEMS bsps need enough
>>>> symbols to define the work area and starting stack.
>>>> Since the linker script has 16mb in it, that is all the RTEMS
>>>> application can know about. Anything beyond that 16mb is free for you to use
>>>> as you like.
>>>> You can look for some tutorials on ld scripts. This is an area of rtems
>>>> that lacks good documentation.
>>>> The only way to know what memory you can use outside of rtems is to
>>>> inspect the linkcmds. In your case though you might be able to just point at
>>>> the 16 MB base address, since psim bsp does not expect to use that much
>>>> ram...
>>>> On May 5, 2013 9:01 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>>>>> Hi Gedare,
>>>>> Can you please explain where/how in linkcmds I should be touching and
>>>>> how to let the bps know about the change?
>>>>> I'm very new to this.
>>>>> Also, how do I calculate how much space RTEMS is taking so I know the
>>>>> address to start creating the partitions?
>>>>> Thanks!
>>>>> On Sun, May 5, 2013 at 9:40 PM, Gedare Bloom <gedare at gwmail.gwu.edu>
>>>>> wrote:
>>>>>> You probably need to modify the bsp linkcmds file, or just malloc a
>>>>>> large chunk. The bsp may need to know about the extra memory in either case,
>>>>>> so check out the linkcmds.
>>>>>> -Gedare
>>>>>> On May 5, 2013 2:46 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>>> wrote:
>>>>>>> Thanks Joel.
>>>>>>> I have modified it to be with 32 MB of RAM.
>>>>>>> Right now my doubt is the following:
>>>>>>> From psim.in or other resources, how can I know at which address I
>>>>>>> can start creating the partitions and make sure it won't give me an
>>>>>>> 'unmapped address' error again?
>>>>>>> Thanks.
>>>>>>> On Thu, May 2, 2013 at 12:06 PM, Joel Sherrill
>>>>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>>>>> I don't know where this all ended yesterday.
>>>>>>>> On 5/1/2013 9:00 PM, Binkowski, Cassio wrote:
>>>>>>>> I know I'm missing out on something. It's probably because of the
>>>>>>>> memory addresses and maybe a custom config is required on that file
>>>>>>>> mentioned by Joel
>>>>>>>> (http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds).
>>>>>>>> I have never dealt with this before and will need some assistance.
>>>>>>>> You could modify the device tree created by psim/psim-gdb to add
>>>>>>>> more RAM or a second bank of RAM after the first 16 MB that the
>>>>>>>> linkcmds knows about. This is in psim.in:
>>>>>>>> /openprom/options/oea-memory-size 16777216
>>>>>>>> The bottom line is that you are reading the mpc5200 PowerPC manual
>>>>>>>> for
>>>>>>>> addresses and that does not have any correlation to the memory map
>>>>>>>> of
>>>>>>>> the "psim board" as defined by the device-tree.
>>>>>>>> 0x10000 is 64k which is in use by the program or RTEMS.
>>>>>>>> 0x100000 is 1MB and is also in use by the program or RTEMS.
>>>>>>>> 0x1000000 is outside the memory map.
>>>>>>>> --joel
>>>>>>>> On Wed, May 1, 2013 at 10:35 PM, Binkowski, Cassio
>>>>>>>>> That may be one solution.
>>>>>>>>> @Joel: Thank you so much for the detailed explanation.
>>>>>>>>> One thing that would be great is that if we could somehow condense
>>>>>>>>> all this information exchanged in the mailing list into the
>>>>>>>>> Wiki/Manuals/Doxygen.
>>>>>>>>> For example, I am now getting another exception, I'm just pasting
>>>>>>>>> some of it, because it's huge:
>>>>>>>>> Suspending faulting task (0x0A010003)
>>>>>>>>> Exception handler called for exception 7 (0x7)
>>>>>>>>> Too many stack frames (stack possibly corrupted), giving up...
>>>>>>>>> Suspending faulting task (0x0A010004)
>>>>>>>>> It's given at the creation of the 7th partition when function
>>>>>>>>> _API_extensions_Run_postswitch() is executed.
>>>>>>>>> How can I start searching for it? I don't know what to look for
>>>>>>>>> inside inter.h.
>>>>>>>>> Best regards
>>>>>>>>> Cassio
>>>>>>>>> On Wed, May 1, 2013 at 10:18 PM, Gedare Bloom
>>>>>>>>> <gedare at gwmail.gwu.edu> wrote:
>>>>>>>>>> You tell the partitions where to start, so just give the second
>>>>>>>>>> partition the right address. You have to be sure the memory you use is
>>>>>>>>>> available both in the hw as real memory and also not used for other
>>>>>>>>>> purposes. Probably you can malloc all the memory you need at startup time
>>>>>>>>>> and pass pointers into the allocated buffer to partition create.
>>>>>>>>>> -Gedare
>>>>>>>>>> On May 1, 2013 7:07 PM, "Binkowski, Cassio" <cassioiks at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hmmm. The 'Testing Task' does not have a while(1) loop and I'm
>>>>>>>>>>> not deleting it. Could that be it? <- Yup, that's it. Just tested. Can you
>>>>>>>>>>> please explain how did you arrive at this conclusion?
>>>>>>>>>>> I'm referring to the MPC5200B board. You can see the manual in
>>>>>>>>>>> the following link:
>>>>>>>>>>> http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
>>>>>>>>>>> Now, mentioning the partitions and memory addresses. I'm not
>>>>>>>>>>> quite sure if I'm incrementing addresses correctly. I do want to create a
>>>>>>>>>>> partition right next where the other one finishes.
>>>>>>>>>>> So, if starting address is 0x10000, the next partition will start
>>>>>>>>>>> at 0x10000 + previousPartitionSize.
>>>>>>>>>>> Does this make sense?
>>>>>>>>>>> Thanks.
>>>>>>>>>>> On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill
>>>>>>>>>>>> It could be another task exiting. You mentioned loading code.
>>>>>>>>>>>> Psim is a specific simulated hardware environment and does not
>>>>>>>>>>>> as configured match any board. If you got addresses from a piece of real
>>>>>>>>>>>> hardware, the addresses will not match. What target board's manual are you
>>>>>>>>>>>> reading?
>>>>>>>>>>>> Ok.
>>>>>>>>>>>> 1) The Init task is already deleting itself after loading the
>>>>>>>>>>>> other tasks. Do I have to do something else?
>>>>>>>>>>>> 2) The memory for partitions came from the board data sheet. I
>>>>>>>>>>>> based myself on the addresses mentioned there and followed upon. I was
>>>>>>>>>>>> creating the first one starting at 0x10000 and incrementing from that
>>>>>>>>>>>> according to each partition's size.
>>>>>>>>>>>> Can you help me set these 2 things up? I'm not really sure how
>>>>>>>>>>>> to deal with that memory issue and the internal error as well.
>>>>>>>>>>>> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill
>>>>>>>>>>>>> That address is invalid for psim. Where does the partition
>>>>>>>>>>>>> memory come from? Here I'd the memory keep for psim
>>>>>>>>>>>>> I'm also getting the following error when I uncomment the
>>>>>>>>>>>>> function that creates 10 partitions to be used by my application:
>>>>>>>>>>>>> core_find_mapping() - access to unmaped address, attach a
>>>>>>>>>>>>> default map to handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000
>>>>>>>>>>>>> cia=0x1028c
>>>>>>>>>>>>> Can you please help?
>>>>>>>>>>>>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio
>>>>>>>>>>>>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>>>>>>>>>>>>> I am using psim-gdb testing my own application, it's not an
>>>>>>>>>>>>>> RTEMS example.
>>>>>>>>>>>>>> I managed to break right on it, and it stops at:
>>>>>>>>>>>>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>>>>>>>>>>>>> Signature is the following:
>>>>>>>>>>>>>> the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>>>>>>>>>>>>> is_internal=is_internal at entry=true,
>>>>>>>>>>>>>> the_error=the_error at entry=5)
>>>>>>>>>>>>>> I have no clue of what it can be. Do you have any idea?
>>>>>>>>>>>>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill
>>>>>>>>>>>>>>> Where is the file events.c?
>>>>>>>>>>>>>>> Break at the fault handler printing that.
>>>>>>>>>>>>>>> Does this happen with any rtems provided examples?
>>>>>>>>>>>>>>> Are you using the psim or psim-gdb script to run it?
>>>>>>>>>>>>>>> Hi everyone,
>>>>>>>>>>>>>>> I was just testing my application using PSIM and it is
>>>>>>>>>>>>>>> returning the following lines, right after starting a Task:
>>>>>>>>>>>>>>> rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC
>>>>>>>>>>>>>>> ERROR 5
>>>>>>>>>>>>>>> events.c:404: assertion failed - events->time_from_event > 0
>>>>>>>>>>>>>>> Has anybody experienced this before?
>>>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>>>> Cassio
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> rtems-users mailing list
>>>>>>>>>>> rtems-users at rtems.org
>>>>>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>>>>> Support Available (256) 722-9985
