RTEMS-4.10.2 Building Error
Tue May 21 12:49:42 UTC 2013
Maybe some problem with your sparc-rtems4.11-binutils? What guide are
you following for building your project?
You might like to check out the RTEMS source builder [1] [2]. It has
known-to-work scripts for building RTEMS tools and RTEMS itself for
many different hosts.
-Gedare
[1] http://git.rtems.org/rtems-source-builder/
[2] http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html
On Tue, May 21, 2013 at 12:05 AM, manish jain <manish8886 at gmail.com> wrote:
> Hi All,
> I was able to build  RTEMS-4.10.2 successfully last time. But due to some
> reason when I tried to build again, I am getting following "Assembler
> Errors". I have checked "sparc-rtems4.11-gcc", it is still working fine with
> ordinary ".c"files. Any input what might be the reason for these errors?
> configure:3440: sparc-rtems4.11-gcc -mcpu=cypress -O2 -g   conftest.c  >&5
> /tmp/ccHERiZW.s: Assembler messages:
> /tmp/ccHERiZW.s:8: Error: unrecognized symbol type ""
> /tmp/ccHERiZW.s:9: Error: unknown pseudo-op: `.proc'
> /tmp/ccHERiZW.s:16: Error: bad register name `%o7+8'
> /tmp/ccHERiZW.s:17: Error: bad register name `%o0'
> /tmp/ccHERiZW.s:25: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:26: Error: unknown pseudo-op: `.uahalf'
> /tmp/ccHERiZW.s:27: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:30: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:32: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:33: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:34: Error: unknown pseudo-op: `.uaword'
> /tmp/ccHERiZW.s:35: Error: unknown pseudo-op: `.uaword'
> configure:3487: error: in
> `/home/manish/tools/b-rtems/sparc-rtems4.11/c/sis':
> configure:3489: error: C compiler cannot create executables
> Thanks
> Manish
> rtems-users mailing list
> rtems-users at rtems.org
