i386-rtems4.11-ranlib: command not found
dave
daveerickson at shaw.ca
Fri Nov 1 20:03:20 UTC 2013
i ran into this error 'make install' ing rtems into /opt/rtems-4.11
folder. I have permission and the ranlib version is available.
sudo make install ends with error:
/usr/bin/install -c -m 644 libsapi.a
'/opt/rtems-4.11/i386-rtems4.11/pc386/lib'
( cd '/opt/rtems-4.11/i386-rtems4.11/pc386/lib' &&
i386-rtems4.11-ranlib libsapi.a )
/bin/sh: line 5: i386-rtems4.11-ranlib: command not found
gmake[5]: *** [install-project_libLIBRARIES] Error 127
gmake[5]: Leaving directory
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit/sapi'
gmake[4]: *** [install-am] Error 2
gmake[4]: Leaving directory
gmake[3]: *** [install-recursive] Error 1
gmake[3]: Leaving directory
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit'
gmake[2]: *** [install-recursive] Error 1
gmake[2]: Leaving directory
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386'
gmake[1]: *** [install-recursive] Error 1
gmake[1]: Leaving directory
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c'
make: *** [install-recursive] Error 1
[dave at localhost build-i386]$ man ranlib
[dave at localhost build-i386]$ ls /opt/rtems-4.11/i386-rtems4.11/pc386/lib
include libsapi.a
[dave at localhost build-i386]$ which i386-rtems4.11-ranlib
/opt/rtems-4.11/bin/i386-rtems4.11-ranlib
is this a configuration error?
Thanks in advance,
Dave
