i386-rtems4.11-ranlib: command not found
dave daveerickson at shaw.ca
Sat Nov 2 03:03:14 UTC 2013
chowned /opt/rtems-4.11 to usr solves problem.
Thanks
Dave
On 11/01/2013 07:15 PM, Gedare Bloom wrote:
> I suspect the issue is root's path, when it executes sh, is not
> picking up the tools. You could chown /opt/rtems-4.11 and just make
> install. I think there are other solutions but I forget offhand.
> -Gedare
> On Nov 1, 2013 4:05 PM, "dave" <daveerickson at shaw.ca
> <mailto:daveerickson at shaw.ca>> wrote:
>     i ran into this error 'make install' ing rtems into
>     /opt/rtems-4.11 folder.  I have  permission and the ranlib version
>     is available.
>     sudo make install ends with error:
>      /usr/bin/install -c -m 644  libsapi.a
>     '/opt/rtems-4.11/i386-rtems4.11/pc386/lib'
>      ( cd '/opt/rtems-4.11/i386-rtems4.11/pc386/lib' &&
>     i386-rtems4.11-ranlib libsapi.a )
>     /bin/sh: line 5: i386-rtems4.11-ranlib: command not found
>     gmake[5]: *** [install-project_libLIBRARIES] Error 127
>     gmake[5]: Leaving directory
>     `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit/sapi'
>     gmake[4]: *** [install-am] Error 2
>     gmake[4]: Leaving directory
>     gmake[3]: *** [install-recursive] Error 1
>     gmake[3]: Leaving directory
>     `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit'
>     gmake[2]: *** [install-recursive] Error 1
>     gmake[2]: Leaving directory
>     `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386'
>     gmake[1]: *** [install-recursive] Error 1
>     gmake[1]: Leaving directory
>     `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c'
>     make: *** [install-recursive] Error 1
>     [dave at localhost build-i386]$ man ranlib
>     [dave at localhost build-i386]$ ls
>     include  libsapi.a
>     [dave at localhost build-i386]$ which i386-rtems4.11-ranlib
>     /opt/rtems-4.11/bin/i386-rtems4.11-ranlib
>     is this a configuration error?
>     Thanks in advance,
>     Dave
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131101/95b817ac/attachment-0001.html>
