Hard reset during RTEMS multiprocessing initialization
John Harwell
jharwell at swri.org
Fri Nov 1 22:14:30 UTC 2013
Hello,
I'm currently working on getting RTEMS 4.10 up and running on the LEON3,
utilizing its multiprocessing functionality. I have a bootstrap that
runs from address 0x0, initializes and checks memory, and then copies
each of two RTEMS multiprocessing node images to addresses 0x40010000
and 0x40080000, with the shared memory location being between 0x40000000
and 0x40001000. The issue I am running into is that when both CPUs come
up and start executing the RTEMS images, CPU 0 (which is RTEMS node 1)
always causes a hard reset during initialization, which then causes the
board to begin execution again from address 0x0, thus repeating the
bootstrap, resulting in a boot loop. As far as I understand, RTEMS can
cause a software trap 0x80 via "ta 0x0", but how does it cause a hard
reset trap? Or rather, what in RTEMS initialization would have the
potential to cause such a thing?
If I step through the RTEMS initialization functions manually in
assembly using GRMON, I can get things up and running; that is, both
Init()s fire and both nodes come up. The problem function at a high
level is bsp_pretasking_hook(), and within that
bsp_spurious_initialize(), which goes through and installs trap
handlers. If I manually step through the for loop that installs the
handlers in bsp_spurious_initialize(), and then let things run normally
from there, everything is ok. If I break right before
bsp_spurious_initialize(), and then set a breakpoint for after the
function returns, and try to let bsp_spurious_initialize() run normally,
the hard reset occurs somewhere in the function body/for loop.
Any idea of what is going on?
Thanks,
John Harwell
Engineer
High Reliability Software Section
Communications and Embedded Systems Department
john.harwell at swri.org
Office: 210-522-5965
Southwest Research Institute (SwRI)
6220 Culebra Road, San Antonio, TX 78238-5166
