Building arm-4.11 toolchain on Ubuntu 13.10
Alan Cudmore
alan.cudmore at gmail.com
Mon Nov 4 01:42:12 UTC 2013
I recently tried building an rtems 4.11 arm toolchain using RTEMS source
builder on the just released Ubuntu 13.10 64 bit.
The build fails on binutils/bfd/doc/bfd.texinfo.
If I patch the bfd.texinfo file as follows, it will build successfully:
:~/Desktop$ diff binutils-2.23.2-orig/bfd/doc/bfd.texinfo
binutils-2.23.2/bfd/doc/bfd.texinfo
325c325
< % I think something like @colophon should be in texinfo. In the
> % I think something like @@colophon should be in texinfo. In the
336c336
< % Blame: doc at cygnus.com, 28mar91.
> % Blame: doc@@cygnus.com, 28mar91.
I also had to make the following change to the
rtems-gcc-4.8.1-newlib-cvs-1.cfg file in RSB:
:~/Desktop$ diff rtems-gcc-4.8.1-newlib-cvs-1-orig.cfg
22,26d21
< # Incompatible with Texinfo 5
< %if %{__makeinfo_ver} >= 5.0
< %error Incomaptible version of makeinfo found!
< %endif
Essentially commenting out the check for Texinfo > version 5.0
After these two changes I was able to get a clean build of the
arm-rtems4.11 tools and build RTEMS for the Raspberry Pi.
Since I have it set up, I can try other toolchains as well, just let me
know.
Alan
URL: <http://lists.rtems.org/pipermail/users/attachments/20131103/736e6652/attachment.html>
