NIOS2 ISR Handler with shadow registers
Tue Nov 26 07:01:43 UTC 2013
Hello Kevin,
On 2013-11-25 22:05, Kirspel, Kevin wrote:
> I have been trying to get RTEMS up and running with a Altera NIOS II processor
> with external VIC and shadows registers (non preemptive mode).  I see that the
> current head has ISR support for the NIOS external interrupt controller but I
> think it is broken.  There is a reference to a variable called
> “_Nios2_ISR_Status_interrupts_disabled” but I can’t find its declaration.   It
> doesn’t seemed to exist.
the support for external VIC works well.  You have to provide something like
this in your BSP:
static void set_isr_status_symbols(void)
   __asm__ volatile (
     ".globl _Nios2_ISR_Status_mask\n"
     ".globl _Nios2_ISR_Status_bits\n"
     ".globl _Nios2_ISR_Status_interrupts_disabled\n"
     ".set _Nios2_ISR_Status_mask, "
       __XSTRING(NIOS2_ISR_STATUS_MASK_EIC_IL) "\n"
     ".set _Nios2_ISR_Status_bits, "
       __XSTRING(INTERRUPT_DISABLE_IL_BITS) "\n"
     ".set _Nios2_ISR_Status_interrupts_disabled, "
       __XSTRING(INTERRUPT_DISABLE_IL_BITS | NIOS2_STATUS_PIE) "\n"
Our BSPs are currently not in the tree since it they are automatically
generated from the design files.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
