Fwd: Application Configuration GUI
Shubham Somani
shubhamsomani92 at gmail.com
Sat Nov 30 09:21:19 UTC 2013
Hi,
My GSoC project was to create an Application Configuration Tool for RTEMS
so as it easily configure it for an application with the means of a GUI and
a TUI.
The GUI has been coded, packaged and tested(on Windows,Ubuntu and CentOS).
It can be cloned from https://github.com/shubhamsomani/GUI (temporary).
The TUI has been coded and tested.(on Ubuntu).It can be cloned from
https://github.com/shubhamsomani/TUI (temporary).
The packaged GUI for Windows,Ubuntu,CentOS can be obtained from here-
1) Windows-
https://docs.google.com/file/d/0B41ApxXt-m4jNmpEekkyRmFtOXM/edit?usp=sharing
2) Ubuntu-
https://docs.google.com/file/d/0B41ApxXt-m4jcUcxcXV1cVVsUUE/edit?usp=sharing
3) CentOS-
https://docs.google.com/file/d/0B41ApxXt-m4jYjdjYUszV2RyeDQ/edit?usp=sharing
Please download and use it. For any doubts you may see-
http://www.rtems.org/wiki/index.php/ApplicationConfigurationGUI
Please use it and let us know if you find any bugs or feedback.
There was concern of how to make sure confdefs.h is in sync with conf.t
which was also in sync with the tool for a specific user. This is a process
issue and there may be technical things to do to help the process but we
don't know what they are.
If you have any suggestions on that, then also please let us know.
Cheers,
Shubham
URL: <http://lists.rtems.org/pipermail/users/attachments/20131130/6267913f/attachment.html>
