Limiting program RAM addresses
Sebastian Huber
Fri Nov 29 09:16:30 UTC 2013
On 2013-11-29 10:03, Mohammed Khoory wrote:
> rtems_ramdisk_config rtems_ramdisk_configuration[] = {
> block_size: 512,
The : notation is a GNU extension. I would use C99 .block_size.
> block_num: 12288,
> location: (void*)0x40200000
> size_t rtems_ramdisk_configuration_size = 1;
This doesn't work, but you can use this:
static char ramdisk_buffer[12288][512];
sizeof(ramdisk_buffer[0]),
sizeof(ramdisk_buffer) / sizeof(ramdisk_buffer[0]),
&ramdisk_buffer[0][0]
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
