STM32F4 discovery makefile
sarraciro
sarraciro at yahoo.it
Fri Nov 1 16:27:50 UTC 2013
I had a troubles with porting the cxx example in C (instead C++).
Probably the problem is in/src/Makefile.
The example is:
hello_c
|--lib
| |--say.c
| |--say.h
|--src
| |--init
The project build the library (I had simply change the names of files
included)
but have a problem to find (link) the builded library.
I tried to define
LIBS= -lstm32f4say.a
and also
LD_PATH= ../lib/o-optimize/
LD_LIBS= stm32f4say.a
I think that I have to change the build rules from:
$(PGM): $(OBJS)
$(make-exe)
to something like:
$(filter %.obj,$(PGM)): ${OBJS}
$(make-obj)
$(filter %.exe,$(PGM)): ${LINK_FILES}
$(make-exe)
With non-rtems platform I can build the same sample with autotools (like
in amhello1_template) ... but what about classic makefile approach...
Any suggest??
Thanks
SC
Il giorno ven, 01/11/2013 alle 01.44 +0100, sarraciro ha scritto:
> I'll check it ...
> thanks for clarification & suggest.
> RC
> Il giorno ven, 01/11/2013 alle 09.51 +1100, Chris Johns ha scritto:
> > On 1/11/2013 5:11 am, sarraciro wrote:
> > > In effect...
> > > I've tried to build the example-v2... with success.
> > > I think that, studying them with care, I may to be able to extract the
> > > needed information to centre the target.
> > Just a little warning about using Makefile.inc to build applications.
> > Support will be removed from RTEMS in a future release. There maybe
> > tools provided to generate equivalent files but that is still a maybe.
> > Personally I am using waf ...
> > http://www.rtems.org/ftp/pub/rtems/people/chrisj/rtems-waf/
> > I will be supporting this way of building application across future
> > RTEMS releases.
> > Chris
> rtems-users mailing list
> rtems-users at rtems.org
Type: application/x-compressed-tar
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20131101/90dbc97b/attachment-0002.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20131101/90dbc97b/attachment-0003.bin>
