struct within float array
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Nov 19 17:24:54 UTC 2013
Hi all,
I have the following problem.
I've declared the following structure
struct str {
int a;
int b;
float arr[2]
in my Init task I declared:
struct *str mystr;
mystr = (str*)calloc(1, sizeof(*mystr)
mystr -> a = 1;
mystr -> b = 2;
mystr -> arr[0] = 1.2;
mystr -> arr[1] = 2.1;
When i plot my value a trap error occours and no valu
is plotted
If my array is of int, all goes good.
Is there a particular problem for float array in structures
with RTEMS? thanks.
Luca
Il 19/11/2013 12:06, Sebastian Huber ha scritto:
> On 2013-11-19 11:56, Leonard Bise wrote:
>> Am I correct in thinking that this section of the RTEMS doc :
>> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Multiprocessing-Manager.html#Multiprocessing-Manager
>> Talks about what I want or is that something else entirely? I'm a bit
>> loss with
>> your comment about multiprocessing support in RTEMS Sebastian.
> RTEMS_MULTIPROCESSING:
> Independent single-processor RTEMS instances share global objects.
> State changes are exchanged by means of message passing.
> RTEMS_SMP:
> One symmetric multi-processor RTEMS instance runs on multiple processors.
URL: <http://lists.rtems.org/pipermail/users/attachments/20131119/61f08c95/attachment-0001.html>
