struct within float array
Tue Nov 19 17:45:31 UTC 2013
Is your task created with RTEMS_FLOATING_POINT attribute?
-Gedare
On Tue, Nov 19, 2013 at 12:24 PM, Luca Cinquepalmi
<cinquepalmi at planetek.it> wrote:
> Hi all,
> I have the following problem.
> I've declared the following structure
> struct str {
>     int a;
>     int b;
>     float arr[2]
> in my Init task I declared:
> struct *str mystr;
> mystr = (str*)calloc(1, sizeof(*mystr)
> mystr -> a = 1;
> mystr -> b = 2;
> mystr -> arr[0] = 1.2;
> mystr -> arr[1] = 2.1;
> When i plot my value a trap error occours and no valu
> is plotted
> If my array is of int, all goes good.
> Is there a particular problem for float array in structures
> with RTEMS? thanks.
> Luca
> Il 19/11/2013 12:06, Sebastian Huber ha scritto:
> On 2013-11-19 11:56, Leonard Bise wrote:
> Am I correct in thinking that this section of the RTEMS doc :
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Multiprocessing-Manager.html#Multiprocessing-Manager
> Talks about what I want or is that something else entirely? I'm a bit loss
> with
> your comment about multiprocessing support in RTEMS Sebastian.
> RTEMS_MULTIPROCESSING:
> Independent single-processor RTEMS instances share global objects.  State
> changes are exchanged by means of message passing.
> RTEMS_SMP:
> One symmetric multi-processor RTEMS instance runs on multiple processors.
> rtems-users mailing list
> rtems-users at rtems.org
