undefined reference to `pthread_setcancelstate' error while building rtems 4.11 with samples.
Fri Nov 22 07:59:40 UTC 2013
On 2013-11-22 01:41, Nadia Gruman wrote:
> Hello,
> I'm building rtems 4.11 on Ubuntu 12.04 (precise) 64-bit for the powerpc
> mvme5500. I have built and installed the tools successfully:
How did you build the tools?  I think you use the wrong Newlib version.
> Has anyone encountered this? I tried adding --enable-posix, but that didn't help.
With POSIX enabled it must work, since in this case pthread_setcancelstate() is
provided by RTEMS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
