undefined reference to `pthread_setcancelstate' error while building rtems 4.11 with samples.
Kate Feng
kate007.feng at gmail.com
Sat Nov 30 23:35:12 UTC 2013
I used the following configure options (before 'gmake') for RTEMS 4.10.2
on Ubuntu 12.04 (precise) 64-bit, and it works well.
../rtems-4.10.2/configure -target=powerpc-rtems4.10
-prefix=/opt/rtems-4.10.2 --enable-cxx --enable-rdbg --disable-tests
--enable-maintainer-mode --enable-networking --enable-posix --enable-itron
RTEMS_CFLAGS=-g -enable-rtemsbsp=mvme5500
gmake RTEMS_BSP="mvme5500
You should delete the old build directory, and restart a new build.
Hope that this helps.
Cheers,
Kate Feng
On Thu, Nov 21, 2013 at 7:41 PM, Nadia Gruman <Nadia.Gruman at pro-dex.com>wrote:
> Hello,
> I'm building rtems 4.11 on Ubuntu 12.04 (precise) 64-bit for the powerpc
> mvme5500. I have built and installed the tools successfully:
> ls /opt/rtems-4.11/bin/
> powerpc-rtems4.11-addr2line* powerpc-rtems4.11-gdb*
> powerpc-rtems4.11-ar* powerpc-rtems4.11-gprof*
> powerpc-rtems4.11-as* powerpc-rtems4.11-ld*
> powerpc-rtems4.11-c++* powerpc-rtems4.11-ld.bfd*
> powerpc-rtems4.11-c++filt* powerpc-rtems4.11-nm*
> powerpc-rtems4.11-cpp* powerpc-rtems4.11-objcopy*
> powerpc-rtems4.11-elfedit* powerpc-rtems4.11-objdump*
> powerpc-rtems4.11-g++* powerpc-rtems4.11-ranlib*
> powerpc-rtems4.11-gcc* powerpc-rtems4.11-readelf*
> powerpc-rtems4.11-gcc-4.8.1* powerpc-rtems4.11-run*
> powerpc-rtems4.11-gcc-ar* powerpc-rtems4.11-size*
> powerpc-rtems4.11-gcc-nm* powerpc-rtems4.11-strings*
> powerpc-rtems4.11-gcc-ranlib* powerpc-rtems4.11-strip*
> powerpc-rtems4.11-gcov*
> and now building rtems. I got the source from git and did the following:
> export PATH=/opt/rtems-4.11/bin:$PATH
> ./bootstrap
> cd ..
> mkdir b-sis
> cd b-sis
> ../rtems/configure --target=powerpc-rtems4.11 --enable-rtemsbsp=mvme5500 --enable-tests=samples --disable-posix
> make
> on make I get the following errors:
> powerpc-rtems4.11-gcc -B../../../../../mvme5500/lib/ -specs bsp_specs -qrtems -mcpu=7450 -mtune=7450 -Dmpc7455 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -mcpu=7450 -mtune=7450 -Dmpc7455 -o hello.exe init.o
> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-fflush.o): In function `_fflush_r':
> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fflush.c:229: undefined reference to `pthread_setcancelstate'
> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fflush.c:231: undefined reference to `pthread_setcancelstate'
> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-findfp.o): In function `__sfp':
> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:111: undefined reference to `pthread_setcancelstate'
> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:135: undefined reference to `pthread_setcancelstate'
> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:124: undefined reference to `pthread_setcancelstate'
> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-fwrite.o):/home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fwrite.c:122: more undefined references to `pthread_setcancelstate' follow
> collect2: error: ld returned 1 exit status
> make[6]: *** [hello.exe] Error 1
> make[6]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples/hello'
> make[5]: *** [all-recursive] Error 1
> make[5]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples'
> make[4]: *** [all] Error 2
> make[4]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples'
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c'
> make: *** [all-recursive] Error 1
> nadgru at lx-test:~/tools/b-sis$
> Has anyone encountered this? I tried adding --enable-posix, but that didn't help.
> Thank you.
> Nadia.
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20131130/5c970940/attachment-0001.html>
