Building rtems-4.11
Kev Fei kev1fei at gmail.com
Sat Nov 23 19:19:07 UTC 2013
Changing the PATH variable to my GCIdevelopment bin did the trick.
I have built RTEMS and the samples run fine.
Thank you!
On Fri, Nov 22, 2013 at 10:31 PM, Joel Sherrill
<Joel.Sherrill at oarcorp.com>wrote:
>  The tools are all in the directory in your GCI development bin directory. Put that at the head of your path .. Not the opt directory.
> Alan Cudmore <alan.cudmore at gmail.com> wrote:
>  Hi,
> Now, Typing "sparc-rtems4.11-gcc" doesn't work :(
> If I go to $HOME/GCIdevelopment/rtems/4.11/bin and do ./sparc-rtems4.11-gcc
> joel.c, it gives me an error.
> /home/kevin/GCIdevelopment/rtems/4.11/lib/gcc/sparc-rtems4.11/4.8.1/../../../../sparc-rtems4.11/bin/ld:
>> warning: cannot find entry symbol _start; defaulting to 0000000000010074
> For this, try  ./sparc-rtems4.11-gcc -c joel.c
> It looks like the compiler is working and is trying to link an executable.
> On your first problem:
> And I get:
> >     configure: error: no acceptable cc found in $PATH
> Do you have the native linux GCC tools installed?
> try:
> $ gcc -v
> and see what it returns.
> Hope this helps,
> Alan
> On 11/22/2013 10:14 PM, Kev Fei wrote:
>  RTEMS Source Builder for Tools
> *Terminal:
>> cd
>> mkdir -p GCIdevelopment/rtems/src
>> cd GCIdevelopment/rtems/src
>> git clone git://git.rtems.org/rtems-source-builder.git
>> cd rtems-source-builder
> --Environment checking
>> source-builder/sb-check
> This turned up for me some
>> warning: exe: absolute exe found in path: (__bzip2) /usr/bin/bzip2
>> warning: exe: absolute exe found in path: (__chgrp) /usr/bin/chgrp
>> warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
>> warning: exe: absolute exe found in path: (__grep) /usr/bin/grep
>> warning: exe: absolute exe found in path: (__sed) /usr/bin/sed
> These programs were installed. For example, I could run grep in terminal.
> However I had to find the programs from the other locations on the disk
> (/usr/bin or /bin or /lib) and copy them over for the next step to work.
> Then it says my environment is ok.
> *Terminal:
>> cd rtems
>> ../source-builder/sb-set-builder --log=l-sparc.txt
>> --prefix=$HOME/GCIdevelopment/rtems/4.11 4.11/rtems-sparc
> This step takes a long time; it took me 46 minutes with downloading. Then
> it ended with an error. It said it could not find python 2.7, but I had it
> installed. After googling, it turned out I had to have python2.7-dev
> installed.
> Finally it built in around 27 minutes.
> *Terminal:
>> ls $HOME/GCIdevelopment/rtems/4.11
>> ls $HOME/GCIdevelopment/rtems/4.11/bin
> Both turned up nice results.
> After reading your comments, I realized I had somehow skipped over this
> step in a newbie mistake :P
>> --prefix=$HOME/GCIdevelopment/rtems/4.11 --bset-tar-file 4.11/rtems-sparc
> Built in 29 minutes.
> I think I might've copied over a bunch of the built tools from the
> 4.11/bin to the /opt/rtems-4.11/bin folder at one point.
>  Maybe I should just start this thing over sometime :P
> Kevin Fei
>> *Terminal:
>>> cd
>> *Terminal:
>>> cd rtems
>> installed.
>> *Terminal:
>> Kevin Fei
>> On Fri, Nov 22, 2013 at 8:33 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> > wrote:
>>> On 11/22/2013 6:33 PM, Kev Fei wrote:
>>> > Hello,
>>> > I am trying to build rtems 4.11 on Linux Mint 13 LTS 64-bit for sparc
>>> as
>>> > part of Google Code-In.
>>>  Thanks for posting this to the users list. :)
>>> > I used the RTEMS Source Builder to build these tools and I think I have
>>> > them installed correctly:
>>>  What command did you use with the RSB? I would have expected
>>> to see the right autoconf and automake versions in this
>>> directory.
>>> More below.
>>> >     ls /opt/rtems-4.11/bin
>>> >     cklength                    sparc-rtems4.11-gcov
>>> >     eolstrip                    sparc-rtems4.11-gdb
>>> >     install-if-change           sparc-rtems4.11-gprof
>>> >     packhex                     sparc-rtems4.11-ld
>>> >     rtems-bin2c                 sparc-rtems4.11-ld.bfd
>>> >     sparc-rtems4.11-addr2line   sparc-rtems4.11-nm
>>> >     sparc-rtems4.11-ar          sparc-rtems4.11-objcopy
>>> >     sparc-rtems4.11-as          sparc-rtems4.11-objdump
>>> >     sparc-rtems4.11-c++         sparc-rtems4.11-ranlib
>>> >     sparc-rtems4.11-c++filt     sparc-rtems4.11-readelf
>>> >     sparc-rtems4.11-cpp         sparc-rtems4.11-run
>>> >     sparc-rtems4.11-difftest    sparc-rtems4.11-sis
>>> >     sparc-rtems4.11-elfedit     sparc-rtems4.11-size
>>> >     sparc-rtems4.11-g++         sparc-rtems4.11-sorttimes
>>> >     sparc-rtems4.11-gcc-4.8.1   sparc-rtems4.11-strings
>>> >     sparc-rtems4.11-gcc-ar      sparc-rtems4.11-strip
>>> >     sparc-rtems4.11-gcc-nm      unhex
>>> >     sparc-rtems4.11-gcc-ranlib  xmlwf
>>> > Now I'm trying to build rtems, following the Quick Start.
>>> > In $HOME/GCIdevelopment/rtems,
>>> > *Terminal:
>>> >     git clone git://git.rtems.org/rtems.git
>>>  >     <http://git.rtems.org/rtems.git> rtems
>>> >     cd rtems
>>> >     export PATH=/opt/rtems-4.11/bin:$PATH
>>> >     ./bootstrap
>>>  Try these steps and let's see what we get.
>>> type sparc-rtems4.11-gcc
>>> Then compile this program ..put it in joel.c
>>> int main() {return 0;}
>>> sparc-rtems4.11-gcc joel.c
>>> What's the output? It should compile just fine.
>>> > First I had to update automake and autoconf. rtems required versions
>>> > higher than what the repositories had, so I had to google them and
>>> > install them from source, which was easy enough.
>>>  The RSB handles autoconf/automake as part of the RTEMS tools
>>> if invoked correctly so I am a bit confused. We need the command
>>> as shown above but if you did this much right, they should be
>>> in your PATH.. so
>>> autoconf --version
>>> automake --version
>>> >     ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
>>> >     --enable-tests=samples --disable-posix
>>> >     make
>>> > And I get:
>>> > Although sparc-rtems4.11-gcc-4.8.1 is already in
>>> > rtems/b-sis/sparc-rtems4.11, I copy the other tools gcc-ar, gcc-nm, and
>>> > gcc-ranlib too.
>>>  This doesn't sound like something you should have done.
>>> > I try the above two commands again and it still doesn't work.
>>> > Output:
>>> >     Making all in tools/build
>>> >     make[1]: Entering directory
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/tools/build'
>>> >     make  all-am
>>> >     make[2]: Entering directory
>>> >     make[2]: Leaving directory
>>> >     make[1]: Leaving directory
>>> >     Making all in tools/cpu
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu'
>>> >     Making all in generic
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu/generic'
>>> >     make[2]: Nothing to be done for `all'.
>>> >     make[2]: Nothing to be done for `all-am'.
>>> >     Making all in testsuites/tools
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools'
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools/generic'
>>> >     Making all in sparc-rtems4.11/c
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c'
>>> >     Making all in .
>>> >     Making all in sis
>>> >     `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c/sis'
>>> >     make[2]: *** No rule to make target `all'.  Stop.
>>> >     make[1]: *** [all-recursive] Error 1
>>> >     make: *** [all-recursive] Error 1
>>> > I have tried --enable-posix instead as well as removing the posix tag
>>> > altogether. Google searches for ***No rule to make target 'all'. errors
>>> > have not been very helpful.
>>> > Does anybody have any ideas on what's going on? Thank you!
>>>  Try the above and post the results. I think RSB was invoked
>>> with something minor wrong.
>>> > Kevin Fei
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>>  Physics!
>> Layton!
>> Nintendo!
>> Wikipedia!
>  Physics!
> Layton!
> Nintendo!
> Wikipedia!
> rtems-users mailing listrtems-users at rtems.orghttp://www.rtems.org/mailman/listinfo/rtems-users
Physics!
Layton!
Nintendo!
Wikipedia!
URL: <http://lists.rtems.org/pipermail/users/attachments/20131123/ec145cd4/attachment-0001.html>
