FLOATING POINT with rtems
Luca Cinquepalmi
cinquepalmi at planetek.it
Fri Nov 29 12:20:14 UTC 2013
Hi all,
I'm not yet able to use FLOATING POINT coprocessor in my sparc architecture.
I configured my system.h by inserting
#define|CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT|
but alway the same trap appears:
Unexpected trap(0 x4) ... fp disabled
I don't want to use -msoft-float flag option because I don't use
it when I compile with BCC instead of RCC and it does work without any
problems.
I don't know why rtems gives me this kind of problems.
Can anyone suggest me something?
Thanks a lot
Luca
Il 19/11/2013 18:24, Luca Cinquepalmi ha scritto:
> Hi all,
> I have the following problem.
> I've declared the following structure
> struct str {
> int a;
> int b;
> float arr[2]
> in my Init task I declared:
> struct *str mystr;
> mystr = (str*)calloc(1, sizeof(*mystr)
> mystr -> a = 1;
> mystr -> b = 2;
> mystr -> arr[0] = 1.2;
> mystr -> arr[1] = 2.1;
> When i plot my value a trap error occours and no valu
> is plotted
> If my array is of int, all goes good.
> Is there a particular problem for float array in structures
> with RTEMS? thanks.
> Luca
> Il 19/11/2013 12:06, Sebastian Huber ha scritto:
>> On 2013-11-19 11:56, Leonard Bise wrote:
>>> Am I correct in thinking that this section of the RTEMS doc :
>>> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Multiprocessing-Manager.html#Multiprocessing-Manager
>>> Talks about what I want or is that something else entirely? I'm a
>>> bit loss with
>>> your comment about multiprocessing support in RTEMS Sebastian.
>> RTEMS_MULTIPROCESSING:
>> Independent single-processor RTEMS instances share global objects.
>> State changes are exchanged by means of message passing.
>> RTEMS_SMP:
>> One symmetric multi-processor RTEMS instance runs on multiple
>> processors.
URL: <http://lists.rtems.org/pipermail/users/attachments/20131129/80e092fe/attachment-0001.html>
