FLOATING POINT with rtems
Sebastian Huber
Fri Nov 29 12:29:40 UTC 2013
Hello,
On 2013-11-29 13:20, Luca Cinquepalmi wrote:
> I'm not yet able to use FLOATING POINT coprocessor in my sparc architecture.
> I configured my system.h by inserting
> #define|CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT|
> but alway the same trap appears:
> Unexpected trap(0 x4) ... fp disabled
which BSP do you use and with which GCC options did you build the BSP?
> I don't want to use -msoft-float flag option because I don't use
> it when I compile with BCC instead of RCC and it does work without any problems.
What is BCC? For RCC support you should probably ask Aeroflex Gaisler.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
