shared library with rtems
Luca Cinquepalmi
cinquepalmi at planetek.it
Wed Oct 2 07:35:06 UTC 2013
Is there a specific Makefile to build rtems shared-libraries?
L.
Il 01/10/2013 14:41, Luca Cinquepalmi ha scritto:
> Shall I use -B instead of -L option in compiling?
> Il 01/10/2013 13:36, Wendell Silva ha scritto:
>> Well, it should work...
>> Could you, please, post the entire command line? The lower case L
>> ('l') sounds very simililar to upper case "i" ('I').
>> 2013/10/1 Luca Cinquepalmi <cinquepalmi at planetek.it
>> <mailto:cinquepalmi at planetek.it>>
>> Yes, sure!
>> Il 01/10/2013 13:15, Wendell Silva ha scritto:
>>> Is there a file named libtestLib.a in lib_path?
>>> Hi all,
>>> I'm trying to compile a shared library with sparc-rtems-gcc,
>>> by using the options -I (include), -L(lib_path) and -l(library)
>>> but the following message appear
>>> ld: cannot find -ltestLib
>>> Shall i use different options? How you tried to do it in a
>>> different way?
>>> Thanks
>>> Luca
>>> rtems-users mailing list
>>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131002/9a078622/attachment.html>
