bootstrap error
dave daveerickson at shaw.ca
Sat Oct 12 16:15:30 UTC 2013
Thanks Ralf;
I did so and it installed the following perl rpm
perl-Thread-Queue        noarch        3.02-1.fc19 fedora         17 k
bootstrapping seems to be working no error.
Thanks!
Dave
On 10/12/2013 03:21 AM, Ralf Corsepius wrote:
> On 10/12/2013 05:31 AM, dave wrote:
>> Hello;
>> I switched to Fedora 19 from Ubuntu and loaded all build tools and
>> the loaded git source.
>> I ran the bootstrap and got then got this error:
>> ./bootstrap
>> Can't locate Thread/Queue.pm in @INC (@INC contains:
>> /opt/rtems-4.11/share/automake-1.13 /usr/local/lib64/perl5
>> /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl
>> /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at
>> /opt/rtems-4.11/bin/automake line 140.
>> BEGIN failed--compilation aborted at /opt/rtems-4.11/bin/automake
>> line 143.
>> autoreconf: automake failed with exit status: 2
>> grep: Makefile.in: No such file or directory
>> ./testsuites/libtests
> Definitely a packaging bug. I don't know the cause, yet - To be
> investigated.
> In the meantime, try
> # yum install 'perl(Thread::Queue)'
> Ralf
